New pushrods
Old Mar 20, 2010 | 02:48 PM
c3_dk's Avatar
c3_dk
Default New pushrods
Hi,
For one of my street engines I've bought Brodix IK180 heads (with guideplates), so I will buy new pushrods, the pushrods will be in moly hardened steel. But what lenght must I buy?
SB 350
Brodix IK 180
1,6 rocker arms
Comp Cams
Comp cams Roller lifter (853-16)
Old Apr 7, 2010 | 01:20 PM
CfieldVette's Avatar
CfieldVette
I have IK180s and I think I got these (2 years ago):
EDL-9630
http://www.summitracing.com/parts/EDL-9630/
I did make sure to measure and see if they were causing my roller rockers to touch valve tips correctly. They were right on.
but I dont have roller cam
adjustable pushrods?
Old Apr 7, 2010 | 01:36 PM
Gordonm's Avatar
Gordonm
You really need to mock up the valve train and see what size you need. There is no one size that fits all. Mock it up and get a pushrod length checker and see what you need. I have a set of .150 longer than stock pushrods on mine but this was after careful measuring.
Old Apr 7, 2010 | 04:10 PM
c3_dk's Avatar
c3_dk
Thanks Gordonm,
I've just bought Comp Cams adjustable pushrod, I hope this will help me finding the lenght I need.
Old Apr 7, 2010 | 10:15 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Try doing it the easy way - use a Moroso or ProForm p-rod checker.
If your engine is still in the car u will find that adj p-rod very difficult to use. BTW did u try a forum search on p-rods. This subject gets discussed here on a regular basis.
Anyways the cheap $15 p-rod checkers just measures the distance between a stock p-rod and either your valve tip or the p-rod to the rocker arm with a feeler gauge. U will need a longer p-rod if gap is on the p-rod side of rocker arm or a shorter p-rod if gap is on the valve tip side of rocker. Any gap less than 0.010" forget about it. U an't gonn'a race for big $$$ at Daytona are ya?
U will be fine within 0.010" and i buoght my Trick Flow p-rods from summit. And guess what? They were a little longer that the engraved number on the p-rod - as i measured with a long calibers. Not a big deal as long as the rocker tip stays centered on the vlv tip and away from the edge.
Hope this helps save a lot of effort and headaches. I tried that adj p-rod while engine in the car and gave up after 2 days.
Better luck to u,
cardo0
To New pushrods
