Under Hood detailing
Old Mar 21, 2010 | 01:28 AM
fwillison's Avatar
fwillison
Default Under Hood detailing
Ok, my small block 68 was frame off restored about 10 years ago.
The engine compartment looks a little dingy. Valve cover and intake paint peeling/flaking. The black firewall and inner fenders look ok but dull. Same with hoses, a little rust on some clamps and bits here and there. The ignition shielding is in a box and needs rechromed (or bought new). Probably could use some plug wires.
So what to do?
Short of pulling the engine and repainting everything, what would be the best way to spruce it up? How much dissasembly? (carb, valve covers, coil,...)
I'm jealous of all those engine bays in the show cars....
Old Mar 21, 2010 | 01:48 AM
mds3013's Avatar
mds3013
What I did was remove all accessories from front of engine. Removed exhaust manifolds and all hoses. Jacked up one side of engine removed one motor mount at a time and painted engine in place after masking off frame. Painted frame and just worked around everything else. Installed new hoses and belts, cleaned or polished everything else. Looked 100% better. I did this over 10yrs. ago and it still looks good. mds...
Old Mar 21, 2010 | 10:47 AM
fwillison's Avatar
fwillison
cool! never thought of jacking up one side of the engine. How is this done, do you put a jack against the oil pan? If not, where?
Did you remove the intake manifold?
what type of paint?
put up a pic if ya got one!
Old Mar 21, 2010 | 10:55 AM
mds3013's Avatar
mds3013
I used a 2X6 on end and jacked against oil pan rail. Two ton floor jack. Must be sure jack cannot move or 2X6 pivots and comes down. I removed oil pan and replaced gasket. Also removed intake and t-stat housing and painted with spray can. Did not know about Forum at time, there may be better paint available. Had original water pump rebuilt, new fuel pump, thermostat. Repainted air cleaner assy. and used repro. GM sticker. I did not repaint underside of hood or engine bay as I liked the original look. Frame and engine were bare though and had to be painted. I am trying to keep car as original as poss. If photobucket is working I will get pic.. mds...
Old Mar 21, 2010 | 11:13 AM
Alan 71's Avatar
Alan 71
Hi fw,
You've gotten some good suggestions. The more you're willing to take apart the better the job turns out in my opinion.
Here's a picture of my compartment as I worked on it years ago before I decided to lift the body. Even with leaving the engine in place you need to decide how far you're willing to go and for how long (if at all) are you willing to give up driving your car. The second picture is after the body was off. Good Luck!
Regards,
Alan
It's in the detail!
Old Mar 21, 2010 | 11:32 AM
Peterbuilt's Avatar
Peterbuilt
10 years later mine needs so touch up again too!
Old Mar 21, 2010 | 11:44 AM
eastltd's Avatar
eastltd
Like Alan says, "the more you take apart, the better the job"
Old Mar 21, 2010 | 03:54 PM
fwillison's Avatar
fwillison
wow! inspiration...
thanks guys
Anyone else? It's good to see a cross section of approaches with varying degrees of disassembly and ways to put it all together.
Old Mar 21, 2010 | 06:34 PM
OURSHARK's Avatar
OURSHARK
I have done it both with the engine in and out. It is definitely easier with the engine out, but you can do a nice job with it in.
I did an engine compartment with the engine in on a '61 vette.
Take out as much as you can.
You will end up with this.
Just take your time and do it correctly. It will last for years.
Here is a pic. of the vette.
Old Mar 21, 2010 | 08:04 PM
Kahle76's Avatar
Kahle76
[QUOTE=OURSHARK;1573497538]I have done it both with the engine in and out. It is definitely easier with the engine out, but you can do a nice job with it in.
That's a beautiful car! Can you tell me what color of red that is?
Old Mar 22, 2010 | 07:42 PM
OURSHARK's Avatar
OURSHARK
I talked to the owner today, he told me it is called Brilliant Red. It is a Camaro color he thinks from the mid '90s.
To Under Hood detailing
