Help needed - New dash harness, won't start
Old Mar 21, 2010 | 06:25 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default Help needed - New dash harness, won't start
I installed a new dash harness this winter (my old one was a mess of electrical tape, mystery wires and even a marette).
I test fired the vette and no dice.
Here's what I have done so far:
Attempt to start car, starter doesn't roll over.
With key on, I get the seat belt buzzer from behind dash.
If I have seatbelt on or off, car doesn't start.
Tried to start the car standing up, doesn't start
I don't have a bypass relay (am I supposed to?)
Horn works
Turn key on, dash lights up (hand brake light for example)
With key on, 12v to the C connection of the bypass relay, starter works.
D does not have constant 12v.
Where do I go from here?
Old Mar 21, 2010 | 06:42 PM
Peterbuilt's Avatar
Peterbuilt
74 has a 1 year only seat belt interlock system, slide the seats forward and disconnect under the seats to eliminate that problem.
Next check the 'Starter safety switch' on the clutch pedal, purple/white is hot with the key in 'START', purple brings power to the 'S' terminal on the starter.
Old Mar 21, 2010 | 08:04 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Unplugged the drivers seat, the passenger side was already unplugged.
No change, buzzer still sounds, car doesn't turn over
I will check the starter clutch switch next.
Old Mar 21, 2010 | 08:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Pete,
I don't remember for sure.. and you would know more than me.. but don't you have to wire around the firewall relay to get the over-ride out of the system.
Willcox
Old Mar 21, 2010 | 09:33 PM
Peterbuilt's Avatar
Peterbuilt
Pretty sure either way takes the relay out of the system.
I just disconnected under the seats.
If you want to bypass the relay heres how.
Old Mar 22, 2010 | 07:05 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Should there be 12v at "jump here" ?
Old Mar 22, 2010 | 08:17 AM
...Roger...'s Avatar
...Roger...
From memory I remember the override relay connector have 4 terminals.
Looking at the wires coming to the connector you need to jumper the green with black tracer to the purple.
The green/black will have 12v "when the key is in the "start" position.
The purple goes down to the S term of solenoid.
(Side note-the relay we are talking about now is the starter override relay,,you can also jumper inside the car at the interlock relay.)
Old Mar 22, 2010 | 09:13 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I was following the diagnosis steps from the repair manual. For some reason I thought C (jump here) had 12 volts constant, not just when I have the ignition to start.
I'll check tonight to see if I'm getting 12v when starting.
Old Mar 22, 2010 | 09:23 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Just a shot in the dark here is it possible the neutral start switch is out of adjustment or not hooked up, Ron
Old Mar 22, 2010 | 09:42 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Didn't even know I had one, is it taken out of the equation when the clutch is pushed in?
Old Mar 22, 2010 | 10:02 AM
Peterbuilt's Avatar
Peterbuilt
Yes, if the wires going to it are correct.
If the switch is working.
And if it is lined up correctly.
(Your in good hands with ...ROGER... listen to what he says)
Old Mar 22, 2010 | 07:59 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Jumpered green/black to purple, no start.
Stuck my head under the dash, noticed that my clutch interlock wasn't plugged in, jumpered it, car fired up.
Now one more Q.
The prong I jumpered was in a T, but the clutch looks like it's two prongs beside each other. Am I missing a piece of my harness?
To Help needed - New dash harness, won't start
