I want a new alternator
Old Mar 22, 2010 | 11:14 AM
Jay71's Avatar
Jay71
Default I want a new alternator
I want to replace my alternator this week. I need the CS144 due to new stereo system. I've seen guys here use the Powermaster 27294. Does this unit have to be "clocked" ? Also, do I need to upgrade the stock wiring harness ?
Thx !
Old Mar 22, 2010 | 11:20 AM
hugie82's Avatar
hugie82
DurangoBoy has a good write up on this. Check out his avitar.
Old Mar 22, 2010 | 06:33 PM
markdtn's Avatar
markdtn
Lots of info out there on CS130 or CS144 swap. Same plugs and wiring. Stay away from CS130 IMHO. I believe the correct application CS144 with correct clocking is 95-96 Roadmaster (5.7L) or Impala SS.
Old Mar 22, 2010 | 07:43 PM
7T1vette's Avatar
7T1vette
If you put more current through the wiring than was available in your year, yes, you need a wiring upgrade on the power line coming from the alternator. It probably has a 10 awg (red) wire for the alternator output. You could either put another 10 awg wire along with it or change the old one out for a 6 or 7 awg wire. You also need to run a decent sized power and ground wire to your stereo amps along with a circuit breaker in the supply line. If you don't upgrade the wiring, the next thing you smell will be the frying of the fusible link(s) in your car.
Old Mar 22, 2010 | 08:57 PM
Jay71's Avatar
Jay71
Thanks for the help guys ! I finally found DurangoBoy's CS144 paper ... lots of good info. I called my buddy Brett (68 NJConv 454) and he is gonna help me out with this swap.
BTW - Right now I'm watching Corvette Summer with my 5 yr old. He found the dvd in my basement and has watched it four times since Saturday.
Old Mar 22, 2010 | 08:58 PM
ssenay72's Avatar
ssenay72
i just put this one in mine 100amp seems to work well so far. (if this helps any)
http://www.summitracing.com/parts/PWM-27294/
Old Mar 22, 2010 | 09:00 PM
ssenay72's Avatar
ssenay72
Here's a pic, pardon the mess, still in progress...
Old Mar 22, 2010 | 09:12 PM
Jay71's Avatar
Jay71
That looks like it would work for me as well. Can you just drop it in, or do you have to "clock" it ? I assume I have to also get the wiring harness & upgraded wiring to bettery.
Old Mar 22, 2010 | 10:04 PM
ssenay72's Avatar
ssenay72
I just dropped it in and it works fine. I had ac in my car if that makes any difference at all. The wires were ok, although i put a new connector on since the original just wasn't there.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
I did put a whole new alternator bracket as well.
Old Mar 23, 2010 | 09:33 PM
Ray Y's Avatar
Ray Y
I was thinking about running this 140A PowerMaster. Anyone using it? Any issues?
http://www.summitracing.com/parts/PWM-37295/
Old Mar 24, 2010 | 09:59 AM
7T1vette's Avatar
7T1vette
Heck no! That 40 year-old wiring will take anything you throw at it...
Old Mar 24, 2010 | 02:51 PM
Ray Y's Avatar
Ray Y
I meant the alternator, not the factory wiring; which will be modified. Sorry for the confusion.
Old Mar 24, 2010 | 03:09 PM
pws69's Avatar
pws69
Yep - working great here - going on the third year, I believe. Never an issue.
Old Jun 15, 2010 | 10:26 PM
ssenay72's Avatar
ssenay72
Im gonna bring this thread back to life because im not sure if i have an alternator issue or not. But at night with the lights on, the electric fan running, at an idle, my battery gauge drops and the dash lights dim. Course once im moving its fine again. I put the 100amp powermaster in it. I didnt even have the radio on. So is this an indication i need a 140amp? Maybe the fan draws too much? I just dont need a fried harness. Not at this stage, I just got her running again for the road.
Thoughts? Suggestions?
Old Jun 15, 2010 | 11:03 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
My guess is that the Powermaster you bought is the 10SI style which does put out good power but not at idle. The CS144 style that the OP mentions is known for putting out a higher percentage of its' total amperage at lower speeds. It came standard on a bunch of late 90's GM vehicles and is popular for those of us running a lot of modern accessories.
You should also look at the headlight relay mod if you haven't already done so.
Rob
Old Jun 16, 2010 | 09:09 PM
jb78L-82's Avatar
jb78L-82
I recently replaced my 12SI 120 amp altenator which had a weak charge rate at idle with a 140 amp CS-144 alternator, mainly for the high charge rate of the CS-144 at idle. I have not replaced the stock wiring since the only real reason for the change was that I needed about 80 amps of power occassionally, not the 140 amps provided by the CS-144 altenator since the only non stock power requriements on my car are 320 watt 4 hella European hlaogen headlights which I have had on the car since 1983 with the stock wiring. The stock wiring can easily handle that load since it is only 80 amps. If you anticipate needing over 100 amps continuously then replacing the wiring would be necessary, otherwise no.
National Quick Start (http://store.alternatorparts.com/) will provide you a correctly clocked alternator for your car if you call them and they are very resaonably priced.
Old Jun 16, 2010 | 09:31 PM
Bee Jay's Avatar
Bee Jay
Why? I went with the CS130 because the 144 was much heavier. I run two radiator cooling fans, upgraded 100watt headlights an electric water pump, and electronic fuel injection. It has been fine.
Bee Jay
To I want a new alternator
