rear alignment
Old Mar 24, 2010 | 11:52 AM
tmscarguy's Avatar
tmscarguy
7th Gear
Default rear alignment
while looking at my 1978 corvette from the rear, it appears the passenger side tire and wheel is leaning in at the top, can this be fixed with an alignment or is there a weak spring or something else?
Old Mar 24, 2010 | 12:17 PM
zwede's Avatar
zwede
Jack the car up, grab the wheels at 12 and 6 and wiggle. That's to check if your strut rod bushing or rear wheel bearings are shot. If that checks out (i.e. very little play) you need to remove the half shaft u-joint caps, and then pull in/out on the stub axle (the thing coming out of the diff that the halfshaft was attached to). If it moves more than 0.050" it's time for a diff rebuild.
If all the above is ok, and the strut rod camber adjustment is not maxed out, your camber can be corrected with an alignment.
Edit: Spring has to be disconnected at trailing arm before removing half shaft.
Old Mar 24, 2010 | 01:33 PM
tmscarguy's Avatar
tmscarguy
7th Gear
thanks very much
To rear alignment
