Brake Pad Material
Old Mar 25, 2010 | 09:55 PM
Tony Rags's Avatar
Tony Rags
Default Brake Pad Material
Does anyone have an opinion on brake pad material that is quiet, low-dusting, and resistant to heat-fade for mostly spirited street use?
What are the differences between Carbon-Kevlar, Ceramic, Organic, and Semi-Metallic materials in relation to the above criteria?
Old Mar 25, 2010 | 10:00 PM
Solid LT1's Avatar
Solid LT1
Try EBC green or red compound.
Stay away from Hawk HPS unless you want to stop quickly and don't mind dusting.
Old Mar 26, 2010 | 08:14 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
All compounds other than organic usually have a "heat up" time where the don't grab well until they've been heated up. I don't know of any compounds that meet all the criteria. Unless Akebono starts making a ProACT pad for these cars you're going to have to deal with a certain amount of dust.
Old Mar 26, 2010 | 08:38 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I use on all the cars I fix Ceramic pads, no problems so far and the guys love them no squealing and very low brake dust! Ron
Old Mar 26, 2010 | 09:07 AM
G-Sting's Avatar
G-Sting
Ron Rail: Which ceramic pads do you recommend? Just normal street driving here. I have newer VBP pads on my '79, but they are beginning to squeal. Are Ceramics silent?
Old Mar 26, 2010 | 09:08 AM
7T1vette's Avatar
7T1vette
Street racing??? If you actually need those big brakes to do significant work, forget the part about 'low dusting'. You just need to get pads with good stopping power and good fade resistance....and wash the wheels more often.
Old Mar 26, 2010 | 09:21 AM
carbster09's Avatar
carbster09
Default EBC Red Stuff
I fitted the EBC Red Stuff, which used to be the higher perf compound even higher than the green stuff. I found the red pads quite good. The produced little dust and stopped well. Now this was on my Audi S3 as my 'vette is fitted with Wilwoods from Corvette engineering and their pads which are fine.
carbster
Old Mar 26, 2010 | 09:43 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
This is the pad you should be looking at
Carbotech bobcat 1521
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Old Mar 26, 2010 | 09:44 AM
Carbotech Adam
Supporting Vendor
To Brake Pad Material
