car wont turn off
Old Mar 25, 2010 | 10:37 PM
74batmobile's Avatar
74batmobile
Default car wont turn off
Like title says it wont turn off. I had checked the starter and the wires and its good. I checked the ignition switch and made sure it was secure. the ignition key is fairly new ( 2 years old) so im at a loss of what else it could be.
any ideas?
heres a video
http://www.youtube.com/watch?v=MtVYgNNn6HU
sry for the camera phone quality.
any help would be appreciated.
Old Mar 25, 2010 | 10:42 PM
TimAT's Avatar
TimAT
If the wire at the starter (small outboard post) is touching the battery cable it won't shut off. As a test, you could unhook the yellow wire at the + side of the coil and try it.
Old Mar 26, 2010 | 06:25 AM
Attfay Elleybay's Avatar
Attfay Elleybay
I think some aftermarket distributors had a diode leak that could cause this.
Old Mar 26, 2010 | 08:45 AM
...Roger...'s Avatar
...Roger...
the yellow at the + coil "can" supply power and the other cloth covered wire "can" supply power also. If you don't want to separate the 2 wires at the coil (they are crimped together) just remove the yellow at the starter and restart the engine and then see if it will shut off.
I have seen solenoids cause this problem.
( The engine should restart without the yellow connected but if it won't ,run a temporary jumper from the + coil to the + term on the alternator and remove once engine starts. )
A question. How are you shutting the engine down now ?
Old Mar 26, 2010 | 09:24 AM
7T1vette's Avatar
7T1vette
To diagnose this properly, you will have to use an ohmmeter to make continuity checks at the ignition switch, on the starter solenoid, and [maybe] at the distributor (the diode thing in an aftermarket dizzy is a new one on me). Until you find the source of the "no OFF position" problem, you're doomed to 'ride forever'.....
A failed starter solenoid or ignition switch are the most likely candidates, IMO.
Old Mar 27, 2010 | 01:36 AM
74batmobile
I pop the hood and pull the the coil wire...
To car wont turn off
