What temp themostat do I need
Old Mar 12, 2002 | 05:06 PM
Stewart's74's Avatar
Stewart's74
Default What temp themostat do I need
Any ideas?
My L-48 is now modified to the point where it is pushing about 350hp.
Thanks,
Stew
Old Mar 12, 2002 | 05:12 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: What temp themostat do I need (Stewart's74)
Open at 185 would be my choice.
Old Mar 12, 2002 | 05:16 PM
Scott78's Avatar
Scott78
I'd say 180, if memory serves me right. I've heard running to cold creates more wear on engine components and hot is not good either. Have your local parts place get you a Robertshaw #330-180. Thats the high flow type, it's the same one Stewart pumps puts 3- 3/16" holes in so there is a constant flow of coolant even when thermostat is closed. The Mr Gasket one looks identical to it in the Jegs catalog. It'll flow more and it seems to be more accurate on it's opening temp. If your not running any smog stuff, it needs coolant temp higher to trigger some of it's functions.
Scott
[Modified by Scott78, 3:18 PM 3/12/2002]
Old Mar 12, 2002 | 05:55 PM
Paul L's Avatar
Paul L
I would go with 180. I have 192 but without mods.
Old Mar 12, 2002 | 06:18 PM
Steve Grodin's Avatar
Steve Grodin
Definetly a 180, that's what I run in my modified L48.
To What temp themostat do I need
