Hydraulic clutch ???
Old Mar 28, 2010 | 01:04 PM
Fleetwood's Avatar
Fleetwood
Default Hydraulic clutch ???
Well i am finally ready to change my auto to a manual 5 speed and would like to go with a hydraulic clutch setup. Which would be the best master and slave cylinder combination to go for and where can i buy the kit?
Thanks Neil.
Old Mar 28, 2010 | 02:08 PM
zwede's Avatar
zwede
The popular choice for the C3 is a late 80's GM truck master & slave. You will need a custom made hose to connect the two. The truck master is easily adapted to the C3, it just needs the rod shortened. GM used that same master & slave on tons of models and years so they are dirt cheap.
Old Mar 28, 2010 | 02:31 PM
Gordonm's Avatar
Gordonm
I have installed 2 of these. One that came with a Keisler kit thatI installed in a forum members car. It is an internal TO bearing mounted to the front ofthe transmission. They have their own master cylinder and mounting bracket. This system works well. The other one I used an LS1 TO beaing which mounts to the front of my T56 transmission. I used a Tilton master cylinder and made up my own lines. This system is very fast acting. Pedal pressure is a little more than the Keisler setup but nothing to bad for driving.
Old Mar 28, 2010 | 09:32 PM
vette427-sbc's Avatar
vette427-sbc
I did the chevy truck master and slave combo on my car. I made a thread with a bunch of pictures here: http://www.vettemod.com/forum/showthread.php?t=3947
Old Mar 29, 2010 | 01:41 AM
Gale Banks 80''s Avatar
Gale Banks 80'
If you search the site for Hydaulic Clutch you should find a couple of articles I wrote on this very subject. I used three diffrent manufactures parts and they all had goods and bads. I didn't plan on it but I ended up doing a lot of Homework and Trial and Err and I hope that it was done for every one interested on this site.
Old Mar 29, 2010 | 07:51 AM
Fleetwood's Avatar
Fleetwood
Thanks to everone for the help and advise and i really like the idea of a remote master cylinder reservoir, especially with the tight spaces on the vette. I will do a search for a place to buy the GM truck master and slave cylinders. i was just concerned that with the pressure required with an 11" clutch I would need a more powerful hydraulic system. I will also do a search for Hydaulic Clutch articles on the forum.
Cheers Neil.
To Hydraulic clutch ???
