Replacing the starter... need help!
Mar 28, 2010 | 02:20 PM
I just bought this starter:
http://www.summitracing.com/parts/SU...sion|Automatic
I took off my old starter and now i have some questions:
Since the new starter is different, how can i know how to connect the wires? How do i know which one is the positive ore whatever?
Here are the pictures (the one on the left is the old starter. To show how it was connected, i wrote numbers):
Then, my other problem is that the pignon doesn't touch the flywheel.
There is something writtem in the instruction, but i didn't really get it
Can anyone help?
Here are the instruction:
Mar 28, 2010 | 05:55 PM
You don't have the solenoid connections necessary to wire up that starter to a '68-74 car. You would be better off rebuilding your starter and solenoid for about $40 and some time.
Mar 28, 2010 | 06:17 PM
He's right , looks like your missing the " R " terminal. I'm assuming the " S " terminal is that screw on the top.
Mar 28, 2010 | 06:38 PM
Quote:
Originally Posted by
7T1vette
But i already bought the new starter and on the website it says it fits my car... mm..
Mar 28, 2010 | 06:55 PM
I got this one
http://www.summitracing.com/parts/PWM-9200/
It has all 4 posts on it...I haven't put it in yet , but the solenoid does have the " R & S " terminals.
Mar 28, 2010 | 08:43 PM
Mar 28, 2010 | 10:40 PM
..edit..
Apr 4, 2010 | 03:47 PM
ssenay72
I bought and put that one on my car! It works good! No heat problem today and it's 85 degrees!
Apr 4, 2010 | 04:32 PM
I finally got mine it last week too , started right up, no shims or anything. I did wrap mine with a shield anyway, just in case.
