Changing rocker arm ratio??
Old Mar 28, 2010 | 11:37 PM
RIO68's Avatar
RIO68
Default Changing rocker arm ratio??
Have a SB 350 with 3863151 style cam and 1.5 ratio stock rockers. Running World Products Sportsman heads 64cc 200 runners 2.02 intake valves. Would it be worth cahnging to 1.6 ratio rockers for performance and would I have to change valve covers to a tall design--have factory alum style now?? Thanks for any help---
Old Mar 29, 2010 | 12:14 AM
Bee Jay's Avatar
Bee Jay
I went from 1.5 stock rockers to 1.6 and then 1.65 ratio roller rockers. At first I kept my stock L-82 valve covers, but I had to have the drip rails machined off.
Bee Jay
Old Mar 29, 2010 | 12:25 AM
tonak's Avatar
tonak
I have 1.6 rockers on the sportsman head you have and it all works. The pushrod guide holes are supposed to be enlarged if you do go to a 1.6 though. I really don't know if mine were enlarged but I don't see any real wear on the pushrods with ~1500 miles on them. I use the standard valve covers with a THICK gasket. Talls weren't going to work very well due to interferences with things like the brake booster vacuum line.
Old Mar 29, 2010 | 08:33 AM
RIO68's Avatar
RIO68
Did it seem to provide any change in performance that you could tell?
Old Mar 29, 2010 | 09:36 AM
tonak's Avatar
tonak
This is essentially a totally new engine, cam, crank, pistons, intake, heads so all I can say is it has great power. You need to pay very close attention to valve train geometry because the 1.6 changes your coil bind on springs as well as other relationships. I had to replace all valve springs just a short while ago because we were off on spec. New springs and it's awesome. Do searches and you will see posts where people experience a loss of power with 1.6 due to such things.
You can't just toss in 1.6 rockers and expect it to work.
Old Mar 29, 2010 | 09:37 AM
7T1vette's Avatar
7T1vette
In terms of HP/$$ benefit, rocker arm ratio is probably one of the costliest changes to add any power to your engine. It's usually one of the last components to 'throw' at an engine rebuild. Any benefit to a street engine would be difficult to prove (less than a 'handful' of HP).
Old Mar 29, 2010 | 10:00 AM
midyearvette's Avatar
midyearvette
To Changing rocker arm ratio??
