power steering brackets
Old Apr 2, 2010 | 10:57 AM
toyvet1's Avatar
toyvet1
Default power steering brackets
Are power steering brackets, pump and pulley specfic to the Corvette. I bought a chrome parts and they arent lining up. I can tweak it to fit, just wondering..............
Old Apr 2, 2010 | 12:42 PM
MelWff's Avatar
MelWff
did you buy the parts from a corvette vendor? if not they may not work.
Old Apr 2, 2010 | 08:30 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
Remember there is short water pump (SWP) and long water pump (LWP) versions of most brackets. Within those families, you must find out if the brackets you bought are meant to line up with which slot on your crank pulley.
Old Apr 3, 2010 | 12:56 AM
toyvet1's Avatar
toyvet1
I have a Corvette March crank pulley and W/P pulley and on a Corvette waterpump . I bought a adjustable P/s bracket , Chrome P/S pump and billet P/S pulley. If I get the pulley lined up there is a 1/2 inch gap on the back side adjustment stud.
Just wondering if there might be a easier way....
Old Apr 3, 2010 | 01:02 AM
ssenay72's Avatar
ssenay72
I bought the set from march. Water pump, crank and alternator pulley, they line up perfect. The power steering pump is a stock pump with stock brackets. That lines up fine also.
To power steering brackets
