Tachometer Question ?
Old Apr 2, 2010 | 11:35 AM
golfradict's Avatar
golfradict
Default Tachometer Question ?
I have a 1981 Vette, before starting the car the tach reads about 3K RPM, when the car is running the tach goes to zero and stays there. The car is being restored at the present and I am just trying to fix what I can before it goes to the mechanic for tuning. Any help appreciated. ~Randall
Old Apr 2, 2010 | 11:38 AM
sniperdiver37's Avatar
sniperdiver37
have you change anything or done anything to the distro? could have a wire off on the tack side of the cap.
Old Apr 2, 2010 | 11:51 AM
golfradict's Avatar
golfradict
I will check it out today, the car is at the body shop and I will stop by and look for a loose wire or wire off. Thanks
Old Apr 2, 2010 | 12:39 PM
C3 4ME's Avatar
C3 4ME
If you have an aftermarket tach, I would use it to help diagnose the problem. I have the tach out of my 79 right now for problems with mine. It's easy to take out, and yours is the same, so PM me if you need help.
Old Apr 2, 2010 | 03:42 PM
us marine's Avatar
us marine
Had the same issue tach wire was not connected to the filter then to the distro.
Old Apr 3, 2010 | 03:42 PM
golfradict's Avatar
golfradict
Same here, not sure why the wire was disconnected.
Old Apr 4, 2010 | 05:08 AM
hunt4cleanair's Avatar
hunt4cleanair
Could be multiple causes but the first suspect is the tach board. This tech tach article just came out in Corvette Enthusiast and Wilcox has some very informative guides as well.
Tach Boards
To Tachometer Question ?
