Over heating issue
Old Apr 2, 2010 | 02:53 PM
corvettedave383's Avatar
corvettedave383
Default Over heating issue
I have a over heating issue at present, which has appeared over night, I have the dewitts rad, with twin electric fans, which seem fine, come on a correct time, and stays on trying to cool engine, but temp still raises, over 230+, heading for the red, just sitting on driveway idleing, the temp always went to about, 180/190, and stayed there, never went above that temp, fans would come on now and again to keep temp in check, so it seems all is working with that part of the system
The top rad hose is hot, but the bottom rad pipe going back to water pump, seems cool, luke water at most, is that correct, I would have thought that would be hot to?
Iam thinking maybe a issue with the water pump or water thermostat in the intake, whats peoples thoughts?, the waterpump is only a year old, not done very many miles on it, the thrermostat is maybe about 2 years old, engine is the same age, and same with rad and fans, 78 vette
cheers
dave
Old Apr 2, 2010 | 03:10 PM
Racer11's Avatar
Racer11
With a over night change,,I would wonder about the sending unit or gauge issue....Maybe install a temporary aftermarket gauge, the kind that requires no electrical hook up, just the probe that goes in the water port on the intake. And the thermostat could be the bad guy as well
Old Apr 2, 2010 | 05:09 PM
Rebelrob's Avatar
Rebelrob
Do you have a laser temp gun? I have heard many members troubleshoot with this by measuring the temp at the thermostat housing. Let us know what ya find out.
good luck.
Old Apr 2, 2010 | 05:36 PM
71coupe454's Avatar
71coupe454
T-stat stuck closed... if you take it out with the engine good and hot it should be wide open and then close as it cools. If you take it out cool, put it in a pan of water on the stove and see what temp it opens, if it does at all..
Old Apr 2, 2010 | 05:42 PM
Jeff_Keryk's Avatar
Jeff_Keryk
If the temp just keeps climbing, suspect coolant flow problems. Thermostat is an easy repair. If it gets hot around town (in traffic) suspect insufficient air flow across radiator. I like thermo clutches and AC type steel fans. At freeway speeds there is plenty of airflow, so suspect weak or undersized radiator. Of course this assumes a good pump, shroud, etc.
Old Apr 2, 2010 | 05:54 PM
Project80's Avatar
Project80
Old Apr 2, 2010 | 07:09 PM
corvettedave383
Thanks guys for info, when I was driving today, doing about 40 mph, the temp was still rising, still quite cool over here, it must be the thermostat, Ive got a temp gun, I will give that a try tomorrow
thanks
Old Apr 3, 2010 | 10:44 AM
corvettedave383
Well done everyone who said it was the stat!, took it out this morning, run the car for a while , it wouldn't go above 160 f , idleing, drving it around the place, I checked the temp with my thermo gun thing, that agreed with the temp gauge, 160 f, the cooling system must be working quite well, it wont go above that temp, I need to purchase a new stat, which temp stat do peeps recommend?, 150, 180?? etc
cheers
dave
ps. weird how it has stoped working after such a short period of time!
Old Apr 4, 2010 | 02:24 PM
Rebelrob's Avatar
Rebelrob
Get a 180.
Old Apr 5, 2010 | 11:47 AM
Mashman's Avatar
Mashman
Also, they have thermostats that when they fail, they fail into the opened state.
Old Apr 5, 2010 | 12:38 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Am running the fail-open type of stat. Best solution.
To Over heating issue
