What's in your car?
Old Apr 3, 2010 | 02:39 AM
enkeivette's Avatar
enkeivette
Default What's in your car?
List your drivetrain/ suspension specs. I'm curious what the regulars are running around with.
Old Apr 3, 2010 | 02:45 AM
another-user's Avatar
another-user
nothing fancy here
350/300 with a holley DP ( dont remember the model number off hand)
M20 with a hurst comp/plus
VBP GT+ with all poly bushings.
Old Apr 3, 2010 | 08:11 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
68 427/390. Turbo 400 automatic. 3:08 posi rear end. Stock suspension with Yokohama redline radials from Diamondback. Fun to drive
Old Apr 3, 2010 | 09:30 AM
Roughrider's Avatar
Roughrider
'69 427/435...L88 camshaft. A real beast to drive, but a fun beast. Stock suspension.
Old Apr 3, 2010 | 09:59 AM
Gordonm's Avatar
Gordonm
The specs should be in my signature
Old Apr 3, 2010 | 10:15 AM
drwet's Avatar
drwet
'79 with 383, Trick Flow heads, roller cam, Hooker headers, dual exhaust from Corvette Central. 700-R4 trans, 3.55 gears. Vette Brakes Grand Touring Suspension package, 255-60 BFG tires on rally wheels. Steeroids rack & pinion. Only complaint is the trans gearing is all wrong. First gear is way too deep. Overdrive is awesome, though.
Old Apr 3, 2010 | 11:10 AM
sniperdiver37's Avatar
sniperdiver37
81 4 spd car
.30 over block
edelbrock performer package, heads, cam, intake 750cmf
headers
MSD 6al
MSD dist, wires, cap and coil
pro balancer
factory ac
VBP performance plus suspension kit
slotted and drilled rotors
ss/ brake lines
all new steering, lines, pump, everything.
fresh midnite blue paint with lite blue pen stripe down the hood line
new inter.....seats carpet
einki wheels
box of reciepts, empty checking account
Old Apr 3, 2010 | 11:19 AM
straub18045's Avatar
straub18045
-late modle block, 385
-kb forged pistons
-pm rods
-eagle crank
-harland sharp lifters, 1.6 on intake
-airgap intake
-large valve e-tec heads
-edelbrock performer rpm cam
-q-jet, k@n
-high volumn oil pump, canton pan
-kieth dorton high volumn f/p
-aluminum water pump, dewitts rad, black magic electric,cooling fan, l88 hood
-rebuilt gm hei
-jet hot hooker super comp headers, h-pipe, magnaflows
-700r4 trans
-stock 3.55 diff
-vbp full susp. kit
-van steel stock steering componants
-stock rallys, bfg's 245/60 15's
-all redone stock interior
Old Apr 3, 2010 | 11:57 AM
Corey_68's Avatar
Corey_68
see sig
Old Apr 3, 2010 | 12:00 PM
Ironcross's Avatar
Ironcross
Box stock
Old Apr 3, 2010 | 03:24 PM
chevroletman's Avatar
chevroletman
78 Red on Red 4 speed
ZZ4
Old Apr 3, 2010 | 03:40 PM
7T1vette's Avatar
7T1vette
1971 SB Coupe w/THM-400 tranny. All drivetrain components (except for U-joints, of course) are original to the car...and the car turned 200,000 miles in January of this year! The engine has one full rebuild [with factory parts] using .040" over pistons; one lower end refurb (bearings); and two head/valve refurbs over the years. The last one was done a year ago when I had to repair a blown head gasket. The heads were given to my mechanic for a full rebuild, anyway {even though he said they didn't really need it}. As far as I can tell from PO repair records, the tranny has never been out of the car and it still operates flawlessly. It does have some vibration that I believe is due to a worn charging pump/converter hub bushing, and it leaks a bit from the front seal. A full rebuild on that tranny is probably next fall's 'major work' project.
Old Apr 3, 2010 | 03:58 PM
enkeivette's Avatar
enkeivette
Damn, we got some serious power in here. I always thought most of the guys in here were as slow as a Turtle.
Old Apr 3, 2010 | 03:59 PM
enkeivette's Avatar
enkeivette
Gordonm that is some serious wheel power out of a NA SBC. Does that thing run on 91 octane?
Old Apr 3, 2010 | 04:34 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
See profile, still under construction but the parts are sitting here.
Old Apr 3, 2010 | 05:14 PM
68 Yellow 468's Avatar
68 Yellow 468
468 ci BBC/solid roller/Holley fuel injection/ 477 rwhp
6 speed richmond tranny
Van Steel front coil over setup
VBP rear leaf/offset trailing arms/Bilstein shocks
3:36 gears....
Scary fun....
Old Apr 3, 2010 | 06:30 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
original 454 + .020 over
LS6 pistons (9:1 CR)
Lunati 60202 hyd. flat camshaft
MSD 8572 + 6AL box
Stock everything else.
With that setup I ran 13.7@101 mph and 0-60 in 5.1 sec.
To What's in your car?
Old Apr 3, 2010 | 07:31 PM
Gordonm's Avatar
Gordonm
Yes it does. I upped the compression just slightly with the new heads and roller cam and so far it is running on pump gas premium. It has had a fuel injection system and a roller cam and bigger heads since those numbers were done so I'm expecting some more power.
Old Apr 3, 2010 | 09:34 PM
nastee383's Avatar
nastee383
11.2:1 396SBC 244@.050 HR
700R4 3.73 rear VBP susp all poly bushings 245/45/17 255/50/17
Old Apr 3, 2010 | 10:06 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
<---- set-up on my profile.. 406sb, 490hp, AFR heads, auto trans with stage 2 shift kit, 456.1 rear gears etc....
