changing my dash...........
Old Apr 3, 2010 | 08:42 AM
headache57's Avatar
headache57
Default changing my dash...........
I have a crack along the edge of my dash in my 82. i took it to a guy that does inter. repair and he told me that over the years of using stuff like armerol, adisve wont stick. so iam thinking about changing my dash. what i asking is how hard of a job this is. I dont like the idea of the dash cover i hard they never look good just laying over the old one.has anyone done this and if so, how is the fit and finsh.
Old Apr 3, 2010 | 10:01 AM
7T1vette's Avatar
7T1vette
Use a polyester body putty to mend damaged areas in the dash. Before it gets hard, you can use a toothpick to lightly etch some 'grain' into the surface if you need to. Then recolor it with SEM "Color Coat" vinyl dye. You do need to use lacquer thinner on a rag to clean all oils/dirt and Armor-All from the dash surface before you work on it.
Old Apr 3, 2010 | 04:25 PM
JetDoc69's Avatar
JetDoc69
I would try to repair it first like 7T1vette suggested. I just replaced my dash and I have to agree with michalbugno2006. Lots of work and so-so fit for $500. I also tried one of those dash caps and that was terrible. Good luck.
Alex
Old Apr 3, 2010 | 11:05 PM
Ray Y's Avatar
Ray Y
The other problem with replacement is that you have to do so much disasembly it's real easy to get caught up in the "while I'm at it I 'bout as well fix/refurbish/replace".... don't ask how I know. Plan a full weekend because I guarantee you that you will get sidetracked.
To changing my dash...........
