Old Mar 25, 2015, 01:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Droopy rearview mirror fix?
Old Apr 6, 2010 | 11:27 AM
VolVette's Avatar
VolVette
Default Droopy rearview mirror fix?
There must be a good way to fix droopy rearview mirrors? What tricks have you used?
Old Apr 6, 2010 | 11:50 AM
Phil Zell's Avatar
Phil Zell
I cut a piece out of a gallon milk jug and it worked fine, used it as a shim
Old Apr 6, 2010 | 11:59 AM
VolVette's Avatar
VolVette
Huh. I could give that a shot. I've used aluminum foil in the past but it's not holding up any longer.
Old Apr 6, 2010 | 12:08 PM
VolVette's Avatar
VolVette
Old Apr 6, 2010 | 12:19 PM
7T1vette's Avatar
7T1vette
Sit face of mirror into some gasoline or mineral spirits overnight (cover that up to keep fumes down). That will dissolve the silicone glue that holds the glass onto the mirror body. Remove any glue residue. Make two hard metal shims (U-shaped piece) out of stainless steel strip [if you can], then start them under the heads of the riveted [staked, actually] locations that hold the swivel mechanism together. Drive them under the heads with small hammer, etc. If a shim is too thick, you can cut off the riveted heads, so be a bit careful. Put RTV adhesive or silicone adhesive on posts that hold the mirror glass and position the mirror assembly so that the posts are vertical. Set glass onto posts and just let the glass settle on it's own. Let dry overnight & install.
Old Apr 6, 2010 | 01:02 PM
Ravine Speed's Avatar
Ravine Speed
Assuming you mean door mirror...
Do what 7T1Vette said to do.
If you search under "floppy mirror" or something like that, you'll find an excellent How-To with lots of pictures, following the same method. It's what I did a year ago and the mirror is very tight.
Old Apr 7, 2010 | 02:27 PM
VolVette's Avatar
VolVette
Ok, forgive me for not being able to find this, but is this how to a thread in this forum or is this article on the web and should be searched through google?
Old Apr 7, 2010 | 05:22 PM
7T1vette's Avatar
7T1vette
You can Google "Corvette mirror repair" and you will probably see one or more write-ups on it. It really doesn't provide you any more info than what I described...except for the photos, which may be of some additional help to you.
You can also select the "SEARCH" section in the banner above, then enter "mirror" or "mirror repair" into the search box. Check at least a year back for threads on this topic.
Old Apr 7, 2010 | 06:00 PM
08vycpe's Avatar
08vycpe
If you are talking about the ISRV mirror The spring issue of Corvette Restorer magazine I got in the mail has an article with photos on exactly how to do this for your car.
If you are talking about the OSRV mirror do this:
http://forums.corvetteforum.com/c3-g...oday-pics.html
Old Apr 7, 2010 | 07:02 PM
Ravine Speed
Sorry I wasn't specific. I meant searching on the forum, and here, when posts indicate to search, they generally mean on the forum.
The above post actually listed the link (my bad, I was being lazy).
All in all, that's the thread on the fix and it's very good.
To Droopy rearview mirror fix?
