My ignition switch partially turns in it's dash mount when turning the key. Looks like the bezel may need to be tightened, but there are 4 little holes in the bezel apparently for some type of tool.
Anyone had this problem?
Just a FYI for anyone reading this thread. The tool will tighten the bezel nut, but it, by itself, cannot remove the nut. To remove the nut (if for some reason you want) insert the key, turn the key to the ACC position, stick a paper clip wire into the small hole in the face of the lock cylinder. Use the wire to push a small internal push button. Pushing the button, pull the key at the same time and the whole lock cylinder will come out. With it out, you can remove the bezel nut completely.
