76 w/ completely dead electrical. help.
Old Apr 7, 2010 | 05:39 PM
Green76L48's Avatar
Green76L48
6th Gear
Default 76 w/ completely dead electrical. help.
Here's the story...
- Battery good, as determined by the machine/tester at AutoZone
I tend to believe it is not the battery because
- After putting a charge on it for several hours and tests statically at about 12.6 volts and is holding charge several days.
- Vehicle is dead when trying to use one of those back-up/emergency batteries.
- Vehicle doesn't respond when trying to use jumper cables from another vehicle.
- There are no interior lights, and when turniing ignition to start, there is no starter, no click, no nothing.
Because the battery box is behind the drivers seat, I am currently trying to get the grounding bolt out of the frame to clean. I'm also told there is a ground cable from the engine to the frame at the front (somewhere?), which I hope to locate and clean those connections if I can find them. Is garaged, and started fine in the Fall.
My question is Because it is a starting, lights, interior lights, etc problem, I'm thinking it is NOT a problem with any of the individual fuses, or the starter connection. Is there any other point (master fuse of some kind??) where I should be looking for a problem?
...and while I'm thinking of it, what is the routing of the Positive cable? From the battery box to where? ..i.e., what connections does it go thru before it gets to the interior fuse box?
Old Apr 7, 2010 | 06:34 PM
Blue79's Avatar
Blue79
Well, the grounds have to be good. The other one is located on the right side of the engine block and is attached to the frame near the right lower A arm. There's a fusable link or three in the wiring that goes to the starter and solenoid. They can blow internally, but usually cook the thick part of the wire where they sit so it's easy to determine, otherwise, a continutity test of the wires on either side of the link.
Old May 2, 2010 | 07:06 PM
rave3c0's Avatar
rave3c0
I am having the same problem in my 79. Did this help to fix your problem?
Old May 2, 2010 | 07:28 PM
Robert B. Barwick's Avatar
Robert B. Barwick
WOW! I am right now having the same problem with my 76. Please let us know what it took to fix this. I will be trying to slove this myself in the morning.
To 76 w/ completely dead electrical. help.
