Easy Solution for a cooler Interior
Old Mar 14, 2002 | 07:52 PM
DaBo's Avatar
DaBo
Default Re: Easy Solution for a cooler Interior (AlwaysWave)
If in doubt or if it is leaking.....put a valve in both hoses.
If I remember correctly they are cheap.
Old Mar 14, 2002 | 08:25 PM
bence13_33's Avatar
bence13_33
Default Re: Easy Solution for a cooler Interior (73-454)
Actually heat and a defroster are two things that I can not go without on my car. For those chilly cruising nights I like to roll the windows down and turn the heat up a little bit. My windows also seem to fog up rather easily so a defroster is a must. I never use air conditioning...if it's nice out the windows are down. :)
Old Mar 15, 2002 | 12:05 AM
Milest's Avatar
Milest
Default Re: Easy Solution for a cooler Interior (bence13_33)
I just installed two valves today that I purchased at O'Reillys Auto Supply. Seven dollars for the 5/8" and nine dollars for the 3/4" shut off valve (same as shown in previous post photo). Very easy to install between the a/c compressor and the fender hose clip. I have not had a chance to drive and check interior temprature.
Old Mar 15, 2002 | 06:07 PM
page62's Avatar
page62
Default Re: Easy Solution for a cooler Interior (Milest)
Well, I went and bought 2 valves ($3.99 and $4.99 at AutoZone) and stuck 'em in there....great! This is the first mod I've made to by newly-acquired '79 Vette. Haven't had her but 10 days! :yesnod: :cool: :cheers:
