A Couple 4speed Muncie Questions??
Old Apr 9, 2010 | 10:50 AM
Clams Canino's Avatar
Clams Canino
Default A Couple 4speed Muncie Questions??
Let me say thanks in advance...
1. How can you make sure you have a 68-70 Muncie and not a 71-74 ?
2. Can the rear seal be changed with the tranny in the car?
3. What about the bushing right behind it?
Reason I ask is because when I removed my driveshaft slip yoke, the outer area where it would seal looks really worn and bunged up. I
I'm going to replace it... but I want to replace the seal and bushing in there also - to give the new one a fighting chance.
-W
Old Apr 9, 2010 | 01:54 PM
Gordonm's Avatar
Gordonm
-W
1. Take the numbers off the case and post them or look them up.
2. Yes
3. No
Old Apr 9, 2010 | 02:04 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
1. The stamp for '68 would be P8xxx (month, date) with a suffix A for M20 or B for M21. For '69 it would be P9xxx, for '70 it would be P0xxx, etc.
Old Apr 9, 2010 | 02:12 PM
Clams Canino
Thanks! Any idea what would cause the driveshaft slip-yoke to look like crap on its outer surface where it goes into the tranny?
-W
Old Apr 9, 2010 | 02:42 PM
Gordonm's Avatar
Gordonm
Possibly an out of balance drive shaft. I know mine looked like crap when I took my Muncie out. I replaced the bushing when I had mine all apart.
Old Apr 9, 2010 | 02:58 PM
Kevins77's Avatar
Kevins77
The rear seal on the muncie is really easy to do while it is still in the car - just be sure to go pick up a seal puller. It makes the job a whole lot easier having the right tool.
Old Apr 9, 2010 | 05:26 PM
early shark's Avatar
early shark
-W
Front input shaft should be a course spline. With exception of M22 case, there should only be 1 drain plug in main case.
1971 cases have 2 drain plugs and all input shafts are 26 fine spline.
Old Apr 9, 2010 | 08:49 PM
DZRick's Avatar
DZRick
I believe the A-B suffix identifying the M20 and M21 started after the '68.
Old Apr 9, 2010 | 09:03 PM
Faster Rat's Avatar
Faster Rat
Guess so. According to the NCRS Corvette Specifications Guide, the suffixes were added effective October 21, 1968. I neglected to read the fine print at the bottom of the page. Happens when your old eyes get tired and you've had one too many already on a Friday night.
Old Apr 9, 2010 | 11:01 PM
joewill's Avatar
joewill
-W
age and rust.. it will prevent a good seal and you will be complaining of puddles on the floor, get you a new one, they are 85-135$$ or so depending on your spline count..
you don't really need a seal puller just use a hammer and a punch , since it is going in the trash anyway when you put a new one in its OK to destroy the seal..
here's my old and new one.. guess which one leaked?.. it needs to be a mirror finish or it will leak....
Old Apr 10, 2010 | 08:43 AM
Clams Canino
If I might ask, where's the $85 to $135 deal please??
Zip has them for $130 and $160 for the 2 types. (with mine being the cheaper one)
-W
Old Apr 10, 2010 | 12:45 PM
thatcorvetteguy's Avatar
thatcorvetteguy
This might help
http://corvette-world.com/corvette_1...on%20Codes.php
Old Apr 10, 2010 | 05:06 PM
redvetracr's Avatar
redvetracr
I have a brand new 27 spline repop you or anyone else can have for $75 delivered
Old Apr 10, 2010 | 10:05 PM
...Roger...'s Avatar
...Roger...
Yes but its a little tricky.
Old Apr 10, 2010 | 10:18 PM
...Roger...
-W
The original yokes were made a little short IMO which allowed a little wobble,the newer after market yokes are longer and slide on to the output shaft further and have better support and don't wear the rear bushing out.
Old Apr 10, 2010 | 11:45 PM
Clams Canino
OK.. to clarify. Mine has 26 splines by count - but there is a large space where there's a "missing spline" - I presume to allow it to go on only one way?
The one in Joewill's pic is not the one I have - I have the other one that's a little smaller on the yoke and takes a u-joint.
But yes... I'll go for the deal if it's the right one for 68-70.
And what means "repop"??
-W
As I recall... you and I did a pumpkin deal a while back - yes?
Old Apr 11, 2010 | 12:30 AM
redvetracr's Avatar
redvetracr
-W
"repop" is short for reproduction, yes we did a pumpkin deal a while back. it has some rust protection on it but it`s brand new. $75 delivered.
Old Apr 11, 2010 | 09:09 AM
Clams Canino
OK cool! Please PM me your Paypal email addy.
For extra credit - you don't have an a SS e-brake upper spring do you?
-W (broke 1 spring)
Old Apr 13, 2010 | 05:04 AM
stacka's Avatar
stacka
Hi Guys
Would i be right in saying P1K2TA is a 71 M20 gearbox thats in my 68?
To A Couple 4speed Muncie Questions??
