69 Wiper Door Question
Old Apr 9, 2010 | 06:20 PM
steelhorse37886's Avatar
steelhorse37886
Navigator
Default 69 Wiper Door Question
I've got a problem with the wiper door on my 69 thats driving me nuts. Maybe you guys can help. Everything appears to be hooked up correctly. The vacuum canister is new and works fine. Here's the deal... With the vacuum lines hooked up correctly the door will open as it should and the wipers work fine but when the switch is turned off the door will move only slightly to close. By slightly I mean maybe 1/8 to 1/4 inch. To get the door to close I can reverse the vacuum lines at the canister and it closes correctly and stays closed. Again, for it to open correctly I have to reverse the lines into the correct positions. Any help will be greatly appreciated. Thanks in advance....Randall
Old Apr 9, 2010 | 06:36 PM
Duke94's Avatar
Duke94
Make sure the right wiper arm pushes the vacuum valve all the way to the closed position when in the park position.
Gary
Old Apr 9, 2010 | 06:50 PM
steelhorse37886
Navigator
Default wiper door question
Thanks Gary, I have checked it and it is hitting the valve correctly.
Old Apr 9, 2010 | 10:31 PM
19LEW71's Avatar
19LEW71
The red marked hose should be attached to the front of the cannister and green on the back. There was a mix up with that in the aim.
Old Apr 11, 2010 | 10:59 AM
steelhorse37886
Navigator
Thanks but the hoses are connected correctly...
Old Apr 11, 2010 | 11:42 AM
Alan 71's Avatar
Alan 71
Hi SH,
Perhaps you have a vacuum relay that's only directing vacuum to the green hose ( or not enough vacuum to the red hose) and thus when you move the green hose it can perform both functions.
When you turn the wiper off you need to test to determine how much vacuum is in the red hose. Do you have a vacuum gauge or pump like a Mity-Vac?
Regards,
Alan
Old Apr 11, 2010 | 12:17 PM
steelhorse37886
Navigator
Yes, I have a vacuum gauge and I'm guessing you're right...
To 69 Wiper Door Question
