Oil tpm. sensor location
Old Apr 11, 2010 | 06:41 AM
Acid 67's Avatar
Acid 67
Default Oil tpm. sensor location
where i have to install a oiltemp. sensor??
i use the sme engine like this one:
http://i2.photobucket.com/albums/y32...1/IMGP1770.jpg
there are two holes on drivers side
1st over the oilfilter mounting
2nd a bit lower 5th spark plug ( to the left of the silver badge )
which one i have to use?
Old Apr 11, 2010 | 07:10 AM
Ganey's Avatar
Ganey
Oil temp. sensor goes above the oil filter.
Old Apr 11, 2010 | 07:25 AM
Acid 67's Avatar
Acid 67
thanks
the sensor unit is from VDO
http://t3.gstatic.com/images?q=tbn:0...-108-large.jpg
with the length of the sensor ( after the mounting threat about 15mm ) i cant block the oil flow into the filter??
To Oil tpm. sensor location
