Hood Blankets
Old Mar 14, 2002 | 10:43 AM
Koz
Guest
Posts: n/a
Default Hood Blankets
I was under the hood yesterday seeing how it seals.. reference the interior heat problem thread.. anyway I remembered that a friend said I needed a hood blanket.. There's nothing between the hood and the engine.. Should there be? He said that the heat will crack or spider my paint.. Thoughts? Also there was a rubber gasket on the hood that I guess is to seal the compartment but it only goes half way around the hood.. Starts at mid hood on one side..across the windshiled side of the hood and down the other.. Is it supose to go all the way around and down as far as the radiator?
Old Mar 14, 2002 | 12:09 PM
VettePower's Avatar
VettePower
Default Re: Hood Blankets (Koz)
There should be a fiberglass blanket on the underside of the hood, held on with plastic retainers. I just ordered 1 yesterday for my 77. $39.99 for the blanket and $3.00 each for the retainers at Corvette America, who has them in stock. :cheers:
Old Mar 14, 2002 | 01:05 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
My '80 doesn't have one, but the '79 does.
Old Mar 14, 2002 | 01:29 PM
A2Shark's Avatar
A2Shark
I don't believe an '80 model was build with a hood blanket. My '76 has one that I replaced last year, and I have always heard that it's needed to prevent the paint from blistering. Could be one of those wives tales.
I'd like to hear more opinions on this. Mine would sure look better if I could remove it and painted the underside of the hood flat black.
Brian
Old Mar 14, 2002 | 01:54 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I've never seen an 80 that had the blanket, 79 and 81 had them. Sort of strange, but I haven't found any of the parts houses that list one for the 80 (or the 81-82 either.) There isn't any reason why you couldn't add one though. The local 'vette repair guy, gets replacement insulation from the Chevy dealer. He says that the insulation for early 80's Chevy pickups is the same as the stuff under the hood of 76-79 Corvettes and works as a good replacement at $25.00 from the dealer.
Old Mar 14, 2002 | 02:03 PM
verskel's Avatar
verskel
My '68 doesn't have one - had it for 4 yrs. and no paint blisters or cracks from heat & it's a Big Block.
The only cars that suffer from paint-on-the hood problems were late-80's fords.... cheap paint, poor hood insulation.
I feel it's an aesthetic thing. -Originality ? - you got me on that one.
Old Mar 14, 2002 | 05:15 PM
MilesM's Avatar
MilesM
I beleive they were orignally for sound as well as heat.
Old Mar 14, 2002 | 08:02 PM
blademaker's Avatar
blademaker
From: Democracy is two wolves and a lamb voting on what to have for dinner. Liberty is a well armed lamb contesting the vote.
St. Jude Donor '10
Default Re: Hood Blankets (MilesM)
I replaced the one on my '78 right after I bought the car.
The old one was in prett bad shape. Not an expensive item, and very easy to do.
Old Mar 14, 2002 | 08:11 PM
killain's Avatar
killain
Oldtimer
Yes, you need to replace the hood blanket and the rubber gasket only goes half way around the hood.
Binnie77's Avatar
Binnie77
Koz: You are correct in that the weather stripping on the hood did not go completely around. It just goes across the back and down the sides a few inches.
Old Mar 14, 2002 | 08:12 PM
JIM's Avatar
JIM
I had no problem until I went to an aluminum top end. Didnt think that aluminum dissipates heat much faster than cast iron.
Old Mar 14, 2002 | 08:57 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Hood Blankets (JIM)
no aluminum does not disapate heat as well as cast iron.
To Hood Blankets
