Odd engine vibrations and noise...water pump?
Old Apr 13, 2010 | 05:35 PM
Turbotrad's Avatar
Turbotrad
Default Odd engine vibrations and noise...water pump?
Help me solve this puzzle.
My '69 has developed some odd vibrations, here are her symptoms.
-At idle a slight abnormal vibe is felt. Just enough to feel wrong.
-The vibration is paired with a noise coming from the engine bay at a frequency less than that of the engine idle rpm.
-The noise AND vibe remain constant regardless of the clutch being engaged or disengaged while the manual trans shifter is in neutral.
-When I blip the throttle the vibe gets VERY pronounced at 1500 rpm, but then smooths out above 1500 rpm. Again, clutch position creates no change in this test.
-There is slight play in the water pump pulley.
Could a failing water pump shaft bearing cause a significant vibration like this?
I had a failing pump on my Chevy Blazer a year ago, but I can't remember what the symptoms were like (other than leaking at the weep hole and noise).
Since the clutch doesn't seem to change the sound I think I can rule out everything from the flywheel back. But I hope this isn't an internal failure waiting to happen.
Any ideas? Water pump? Engine mount? Worse?
I appreciate your time and knowledge in helping me out.
-Brad
Old Apr 13, 2010 | 06:11 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
-Brad
Well Brad, a motor mount cannot cause a vibration. If the water pump was that loose, you'd notice a LOT of motion in the fan ... plus it would be leaking. That's for starters anyway, now into the problem.
One of the very first things I would check would be the harmonic balancer under the water pump. They are well known to cause shakes when the rubber between the pieces fails and the balancer slips.
Check it & see if the timing marks are correct. If they appear well out of bounds then perhaps it has slipped.
Old Apr 13, 2010 | 06:20 PM
dannyman's Avatar
dannyman
Stethoscope will tell you for sure which accessory is noisy.
A long screwdriver accurately held to the ear and the accessory will suffice! Take care doing this.
Turbotrad's Avatar
Turbotrad
Thanks Paul.
I checked the timing not one month ago so I'll be able to notice if it's changed. Just have to get my timing light out.
Old Apr 13, 2010 | 06:48 PM
Turbotrad's Avatar
Turbotrad
Not that I think it's the pump, but you shouldn't even be able to wiggle the fan attached to the water pump at all, right?
Mine wiggles back and forth a bit, but no green coolant on the driveway.
Old Apr 13, 2010 | 08:52 PM
toddalin's Avatar
toddalin
Leaking header?
Old Apr 13, 2010 | 10:03 PM
cargo247's Avatar
cargo247
Had the same thing with mine. mine is an 81 350 but a water pump is a water pump, i had just a little movement in the pump shaft no leaks, at first i thought it was a valve on its way out, take the belts off and see how much movement you get if any change it out or get it RB, pumps are cheap and nice to have a new one in and not have to worries about it on the road letting go.
Todd
Old Apr 13, 2010 | 10:28 PM
Turbotrad's Avatar
Turbotrad
I'll try taking the belts off and running the engine for a short time without them on to notice any changes in the vibrations.
Also, this vibration feels mechanical so I doubt it's related to a leaking header. But I have been wrong before.
Thanks for the help thus far!
Old Apr 14, 2010 | 12:37 PM
Turbotrad's Avatar
Turbotrad
If I do discover the problem is my harmonic balancer, how do I find out which type to buy for replacement?
Are they stamped on the balancer?
Old Apr 14, 2010 | 01:06 PM
toddalin's Avatar
toddalin
See this months Car Craft Magazine.
On their Rambler engine (that had been running fine) they noted that it sounded like someone had a ball peen hammer and was beating the heck out of the innards.
They got all kinds of experts and no one knew what to make of it. One of the experts noted it was a leaking header.
Seems that the header bolt was too long and bottomed out. The editor, who has done beaucoup engine builds, noted this was the first time he ever heard a header leak sound this violent.
Old Apr 14, 2010 | 01:51 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I've seem guys change cams because of ticking header
Old Apr 14, 2010 | 01:55 PM
Turbotrad's Avatar
Turbotrad
I had a leaky header last year about this time and replaced it, so I'm familiar with the sound.
But that doesn't explain the vibration. Hopefully I can figure it out soon when I get some free time.
Old Apr 14, 2010 | 10:34 PM
cam cooper's Avatar
cam cooper
i agree with everyone check bal,headers,take belts off to rule out water pump and as.u would havet to run engine a while to case prob. if that dont help u need to look back at clutch/flywheel ***.
Old Apr 15, 2010 | 12:36 AM
Turbotrad's Avatar
Turbotrad
Alright...quick update
Checked timing and it looks fine. 8 deg BTDC like it has always been.
Didn't have time to loosen and remove the accesory belts but
Alternator and power steering pulleys look fine.
Water pump pulley has a slight wobble. When engine is off I can grab a fan blade and wobble the fan a little bit.
Next to remove the belts and give it a shot.
Old Apr 15, 2010 | 12:38 AM
Turbotrad's Avatar
Turbotrad
Oh yeah, quick question.
At idle should the timing mark on the balancer ever jump around a little bit?
Mine sits at 8 deg BTDC, but every few seconds the mark will do a small jump, is that normal?
Old Apr 15, 2010 | 01:52 AM
toddalin's Avatar
toddalin
Slop in the distributor? Maybe needs a shim?
Old Apr 15, 2010 | 02:15 AM
Turbotrad's Avatar
Turbotrad
Hmmm...might be yet another issue to consider.
Can you explain the basics of distributor shimming?
To Odd engine vibrations and noise...water pump?
Old Apr 15, 2010 | 12:24 PM
toddalin's Avatar
toddalin
Basically you get slop in the shaft at the gear allowing the distributor gear to move up and down a little affecting the timing as the distributor gear position changes relative to the cam gear.
You need to pull the distributor and check the play in the bottom gear on the shaft. I believe that Lars has a paper on this.
Old Apr 15, 2010 | 06:42 PM
cam cooper's Avatar
cam cooper
if this is org. dis. in car and your having the timming jump around u should think about upgrading to a new one keep the old one so u can say u haveit for resale but dont wast your time on shimming and rebuilding a new msd is 10 times better than anything chevy ever made in 69
Old Apr 15, 2010 | 09:32 PM
Turbotrad's Avatar
Turbotrad
Not sure if it's original, but it does have a Mallory electronic conversion kit on it so it's definitely not completely stock.
So let me get this straight, you WANT slop in the distributor shaft? You don't want it bottomed out on the oil pump drive shaft?
