? for cam experts
Old Apr 13, 2010 | 06:25 PM
Billysvette's Avatar
Billysvette
Default ? for cam experts
Is a retrofit cam the same as a small base circle cam?
Old Apr 13, 2010 | 07:16 PM
Gordonm's Avatar
Gordonm
No. The small base circle is for long stroker cranks. It reduces the overall diameter of the cam so it does not hit the crank. A retro fit roller cam is for a non roller block, pre 86 blocks. You can have a small base circle retro fit or non retro fit.
Old Apr 13, 2010 | 07:32 PM
69vettester's Avatar
69vettester
And A retrofit cam Means it must be used in a block thats not machined for the later OEM roller cams and lifters. OEM roller assemblies have shorter pushrods and a "spider" retainer setup for the lifters. Pictures of this spider assembly are surprisingly hard to find. But its very simple type setup.
Base circle is not related directly to whether the cam is a retrofit roller or an OEM roller.
PS, Im not a cam expert but I did a 383 OEM roller block Build up a few years ago.
Old Apr 13, 2010 | 07:43 PM
Billysvette
OK,i have a non roller older block with a 383 stroker kit in it and i bought a edelbrock retrofit cam for it why does everything works great.Also if you were to buy a retrofit cam and then you bought a small base circle cam under the same cam grind ,would all the specs be the same,like the duration and lift?
Old Apr 13, 2010 | 07:52 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yes
Old Apr 13, 2010 | 08:05 PM
69vettester
It works great because you bought a retro roller camshaft and it is designed for your non roller block. OEM roller parts are cheaper than retro roller parts but not better.
I dont see why the same grind, retro as oem would have a different base circle dimension? But I dont know that for sure..maybe a cam expert from both schools would know for sure.
Old Apr 13, 2010 | 08:15 PM
Billysvette
Originally Posted by MotorHead
Yes
Ok Wayne heres one for ya,i just bought a small base circle cam for my engine to try out,and its the same cam as the retrofit one,its a 294D extreme energy cam,the lift numbers are the same,but the duration is different,the retrfit one is 294/300 and the small base circle cam that i bought is 293/299,i know its not much,but why is it different?and the opening and closing of the valve timing is different too,i dont get it why are the two cams that are suppose to be the same have different numbers? do you guys know why?
Old Apr 13, 2010 | 08:21 PM
Billysvette
I think i know why i can run a retrofit cam in my engine with no issues,its because the stoker kit i bought was already clearanced for the cam,which i think my crank was clearanced also .
So if i am right you cant run a retrofit cam in a older non roller block unless the crank and rods are clearenced,right?
Old Apr 13, 2010 | 08:27 PM
Gordonm's Avatar
Gordonm
I run a retro fit roller cam in mine and have stroker rods but the crank is astroker but not clearanced. This is where everything gets tricky. No matter what you have you better check clearances. Some blocks will let you run it others won't. I would not say anything will fit unless I did it myself. A lot depends on the lift and duration of the cam. Some roller have very little lift so the lobes are not very tall and will cear the crank and rods. If you have a very big lift it might hit. Check all the clearances!
Old Apr 13, 2010 | 08:32 PM
Billysvette
Gorgonm can you answer my question about my earlier post about the two cams being the same with different numbers?
Old Apr 13, 2010 | 08:41 PM
Gordonm's Avatar
Gordonm
Can't really answer that but those numbers are so close you would never know any difference between the two. Are the numbers at .050 the same. The advertised duration is something I never look at because they all are measured differently. The .050 numbers tell more about the cam.
Old Apr 13, 2010 | 09:34 PM
Billysvette
Gordonm you might be hitting on something here,the .050 numbers are the same between the two cams,go figure why different numbers on advertised duration then.The other numbers are different though,opening and closing valve timing.dont know if that matters.
Old Apr 14, 2010 | 10:46 AM
gkull's Avatar
gkull
Advertized duration numbers are pulled out of a hat for marketing. One company might measure @.004 lift another .007.................
The duration @.050 gives a closer comparison number. When I look at cam lobes the .200 lift duration numbers really tell the true ramp speed.
Look up some cams and you will see the .050 could be the same, but the .200 might be very different.
Whenever you change base circle size you have to change the length of the push rod the same amount.
Old Apr 14, 2010 | 02:57 PM
Billysvette
Are you saying if i change over to a small base circle cam i will have to change pushrods ? Why? I already changed when i put in the retro hydraulic roller in my engine,wouldnt it be the same length pushrods for a small circle base cam?the lift and everything should be the same i would think?
Old Apr 14, 2010 | 03:31 PM
DRIVESHAFT's Avatar
DRIVESHAFT
When the base circle of the cam is reduced, the lifter will sit further down in the bore when it is riding on the cam's base circle.
Since that will put the lifter further away from the rocker, a longer pushrod is needed to compensate.
Old Apr 14, 2010 | 03:38 PM
midyearvette's Avatar
midyearvette
you must check pushrod geometry before you install a "regular" length set.....
Old Apr 14, 2010 | 04:26 PM
Billysvette
But wait its the same lift and duration as the other cam how can you go with longer pushrods if they are the same?
To ? for cam experts
Old Apr 14, 2010 | 04:47 PM
midyearvette
because the base is smaller...think about it....im not saying your pushrods are wrong, maybe they are correct if they came in a kit, however if indeed the lifters are lower in the bores as stated previously, then the length could be different..you must check geometry to be sure...just because the two cams have the same specs, if they are two different diameters, they require pushrods to compensate for the difference......jmo....good luck....
Old Apr 14, 2010 | 05:33 PM
Billysvette
I understand how to do pushrods,what im not getting is why i might have to,i will check when i put cam in,but,the two cams a retro fit and a small base circle cam with same specs,i would think have to use the same pushrods because the lift has to be the same ,right,and if i change pushrods that changes the geometry of things.600 lift on a retro as to be the same as sm base circle.if you were to measure from the center,right?
My brain is frying here
The only thing that would be different is when the valve is closed ,on the sm base cam pushrod will go deeper ,right
Old Apr 14, 2010 | 05:46 PM
midyearvette
aha!!...you caught yourself...you dont measure from the center of the cam, you measure from the base circle of the cam, or the lash of the base circle to put it another way...if one shaft is a smaller diameter than the other, then the pushrods could be different for the two but that is why you need to check geometry and i would use a manley checker..very cheap and precise, it looks like a plastic rocker arm..there are a lot of mills running the wrong length pushrods and the owners are clueless, you cannot take a generic opinion here as each mill is slightly different and many factors come into play for pushrod length ...good luck....
