Alternator Question
Old Mar 14, 2002 | 03:50 PM
Stewart's74's Avatar
Stewart's74
Default Alternator Question
My 74 came w/a 42 amp alternator. Can I substitute a 64 in its place without any problems?
I dont want to fry everything.
Stew
Old Mar 14, 2002 | 04:02 PM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: Alternator Question (Stewart's74)
A 64 amp alternator should be fine :cheers: . Mine is low amp too, but I think there were higher rated alternators than 64 amp installed from the factory, so there shouldn't be a problem.
AC
Old Mar 14, 2002 | 04:20 PM
Corellian Corvette's Avatar
Corellian Corvette
Default Re: Alternator Question (A C)
If you're getting an alternator from a local auto-parts store, and there was a higher stock rating for your year, you're likely going to be able to only find that one. Bottom line - no problems.
Old Mar 14, 2002 | 04:41 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I replaced my 63amp unit with one from a late 80's Camaro. It is a 90 or 95 amp unit, a couple of years ago Chevy Hi-Performance ran an article on it. I got mine at Autozone for about $40.00, they took the old pulley and fan off my alternator and put it on the new alternator. It works great, charges my system, with plenty left over for my CD-changer, and audio amps.
Old Mar 14, 2002 | 05:00 PM
Kingt's Avatar
Kingt
Default Re: Alternator Question (Smokehouse69)
An alternator's rating is it's ability to supply current. It doesn't "force" 65 amperes into the electrical system. However, if the system needs that ammount it can supply it. Therefore replacing a 42 amp with a 65 amp will not affect the system.
:flag
Old Mar 14, 2002 | 07:14 PM
8T1-7T9 BIONIC VETTE's Avatar
I replaced my stock alternator with a one wire 150 amp alternator and I haven't fried anything yet..... :seeya Cappy
To Alternator Question
