GM Tech 1
Old Apr 14, 2010 | 06:40 PM
10.5Vette's Avatar
10.5Vette
Default GM Tech 1
Does anybody know if a GM Tech 1 will work on an 82, for dignosing problems or check engine lights? Does it need a special adapter? I was told that 82's are pre OBD 1 and use a different operating system.
Old Apr 14, 2010 | 06:50 PM
gerry72's Avatar
gerry72
Yes, it will work. The application for it is GM 1980-1993. You will need the adapter cable so if you're buying this used, you need to make sure it comes with all connectors and software. There are alternatives to the Tech 1 but they come with the same caution. Nothing worse than buying a used high-end scanner and not having all the bits and pieces that make it work.
Old Apr 14, 2010 | 06:55 PM
10.5Vette's Avatar
10.5Vette
I already have the Tech 1. I have the OBD1 cable that came with it and a master cartridge. I was wondering if the cable that came with it will work or if I need an adapter. I don't have the car here to look at the ALDL, a guy wants me to look at his 82 and I just want to make sure I have everything I need before I go over there.
To GM Tech 1
