Gas Mileage
Old Apr 14, 2010 | 10:05 PM
ssavvy's Avatar
ssavvy
4th Gear
Default Gas Mileage
Original 1979 Corvette 41000 miles 350 195hp getting only 10mpg new tune up new carb. new fuel filters new plugs & wires new Dist. Anyone with an idea of why?
Old Apr 14, 2010 | 10:14 PM
1980 blue L48's Avatar
1980 blue L48
New Tune Up ? New Carb ? New Dist ? How does it Run ? Who`s New Carb ? Distributor Cap or the whole assembly ? Need More Info Please.
Old Apr 14, 2010 | 10:18 PM
cam cooper's Avatar
cam cooper
i would be happy with 10 mpg the way i drive
Old Apr 14, 2010 | 10:24 PM
ssavvy's Avatar
ssavvy
4th Gear
Whole Assembly Rebuilt by Corvette expert Carb It actually run real good I was told that it could be the catalyic Conv. but it doesn't seem to be holding back or running rough so i'm not sure about that what do you think?
Old Apr 14, 2010 | 10:37 PM
Goody's Avatar
Goody
Get one of those IR temp guages and take a reading from each exhaust port and see if they are all within a few degrees of one another.
What are the timing settings? Initial and advance? At what RPM do you have full advance?
Are the tires at correct PSI?
No dragging brake pads?
Tranny/clutch isn't slipping?
Old Apr 14, 2010 | 10:44 PM
1980 blue L48
A restricted Converter will hurt your mileage for sure. 79s were a very restricted design to start with. A muffler shop might suggest a test tube, or a more modern Cat. My 80 varies from 14-18 If I Drive like an old lady. Its all stock, except test tube in place of the CAT. I made a templet out of cardboard, showing legth, and bend location. Showed the muffler guy, He made it ,using my homemade Flanges( He said they were obsolete) and handed it to me for $20. He could NOT install it for me. Its a Law thing.
ssavvy's Avatar
ssavvy
4th Gear
I will try your suggestions soon but what do you feel about the Cat?
Old Apr 14, 2010 | 10:48 PM
ssavvy's Avatar
ssavvy
4th Gear
That,s a lot better than 10mpg I get that no matter how I drive. What is a test Tube is that a cheater pipe and where to get one?
Old Apr 14, 2010 | 11:16 PM
7T1vette's Avatar
7T1vette
A "test tube" is a dummy pipe that is inserted to replace the CAT. For you, the purpose would be to see if your mileage improves with it instead of the CAT. If not, put the CAT back on. Then you might look into vacuum leaks which are screwing up your idle settings.
Your car should be able to get about 15 mpg on combination in city and highway driving (city alone might be 10-12 mpg; highway only about 17 mpg). Good luck.
Old Apr 15, 2010 | 08:33 PM
Goody's Avatar
Goody
Some may suggest that you remove the cat and use the test pipe. That may at least prove the clogged cat theory correct. If it is the cat then I say just buy a new modern cat that is free flowing so you still get all the power your engine can create and keep the carbon footprint down.
The vacuum leak previously mentioned can also be a cause.
Slipping torque converter.
Driving style and engine RPM range are also factors.
To Gas Mileage
