80 model coil spring change-out HELP!
The Shop Manual (page 3C-16 & 17) refers to using Adapter tool # J-23028 during the changeout process.Can that tool be rented?
Can anyone shed some light on how-to-do this job? I WILL tackle it if I have some other feedback besides whats in the Shop Manual.
Ever done it? How difficult? Any pointers?
Thanks, Mike J.
Like 1980blue said unseat the ball joints with the castle nuts still on. getting those ball joints out of the taper is tough.
Another option is to secure the spring with the rod and disconnect the lower A-arm from the frame. this will come off with less effort than the ball joints however when you go to put everything back together it can be tough to line up the A-arm to frame. You a basically lying under the car with no room to move with a loaded spring ready to smash your arm,head whatever if the homemade spring compressor (rod) lets go!!! As an insurance support the A-arm with a jack while you are reconnecting it. Don't rely on a jack without the rod.
Not a nice job but do-able
Dale
Thanks, Mike J.
* make sure tires are all the same ratio, brand and date coding for the best consistancy.
* make sure tires are all inflated to same pressure.
* make sure tires have about the same amount of tread remaining.
You should be able to rent a coil spring compression tool or maybe buy one from Harbor Freight or the like. I did springs on a 77 Camaro a couple decades ago but have not done my 81 Corvette yet. That comes next year.
http://forums.corvetteforum.com/1573487895-post3.html
Here are some pics of the spring removal install etc.
The top pocket has an alignment hole that takes a short 5/16" bolt to butt the coil end against.
The spring compressor fits with no problems, no chains required.
Support the car on high jsck stands under the front frame horns.
The other usefull little thing are the wooden blocks for the disc pads. Cut them a hair wider than the disc width, loosen the bleeder a hair and drive them in between the pads. Saves a lot of fooling around with the brakes.
After reading noonies valuable info, I spent the most of the day taking measurements once parked on level ground. Got my wife to help, she found that the drivers side rear wheel was sagging also.( at least she pointed it out to me.) Well.. using a level at the rear steel leaf spring we found the leaf spring is SPRUNG. There is a noticable sag near the end,whereas the pass side still retains a slight arc until it meets the bolt at the end.
Looks like I will replace the rear steel leaf spring first with a new fiberglass before going back up to the front. I think this will solve the drivers front from sagging ,since the pass rear is now a full inch higher than the drivers rear (at the wheel wells)>
My thanks to all that contributed to this thread, and I opologize for leading you guys into another area. I should have taken more time and inspected the car before posting.
Thank you all again.Hope I can return the favor one day.
Good luck with the repairs.
Well- this one I did not tackle and let the local shop do it. Dropped it off at 7;30 am, picked it up at 4;00 pm.
She rides and looks like a new one.
The noticable slump to the front drivers side is gone, all 4 corners are level. Ended up with New Old Stock front coils _many,many thanks to Paul Borowski -Corvette Forum member
A breath of fresh air into the project.
Guys and gals- if your ride is leaning, check ur front coils....
