let the work begin.
Old Apr 16, 2010 | 05:14 PM
tyler77's Avatar
tyler77
Default let the work begin.
Can you change out a rod or rod bearing from underneath through the oil pan opening. thanks
Old Apr 16, 2010 | 05:18 PM
gerry72's Avatar
gerry72
A bearing, yes. A rod, no. You can not withdrawl the piston out of the bottom of the engine. But there's some texture in the bearing question since sucess depends upon the condition of the crank journal. Putting a new bearing on a crank that needs a regrind is not a consideration you should even ponder.
Old Apr 17, 2010 | 05:38 PM
Jack Wood's Avatar
Jack Wood
Default Do it right or do it twice
Pull the engine and rebuild it right. Or you'll install problems and be right back where you are now. "There aren't any easy solutions but there are some simple ones." - Ronaldus Maximus
Old Apr 17, 2010 | 05:55 PM
jordan89's Avatar
jordan89
To let the work begin.
