Removing Trans slip yoke seal
Old Apr 19, 2010 | 10:50 PM
pwcheenie's Avatar
pwcheenie
Default Removing Trans slip yoke seal
Have the drive shaft out on my 80 vette. Would like to change the slip yoke seal on the 4 speed transmission. Anyone have any good suggestions on how to get it out without doing any damage to the spline shaft?
wombvette's Avatar
wombvette
There is a tool.
Old Apr 20, 2010 | 10:55 AM
jimvette999's Avatar
jimvette999
The tool mentioned is best/easiest but if you don't have much room to operate it, it may not be efficient. I'd use a wide blade (1/4") chisel or old screw driver. Just crush the seal in on itself by hammering towards the shaft. That will losen it enough to pop it out. Wipe the oil residue out of the tail housing with brake cleaner or equiv. and use thin bead of weathersrtip adhesive around new seal circumference and tap seal in evenly. Put a small amout of trans. oil on the yoke to lubricate the seal. Not much chance of damaging the spline on the shaft unless you get carried away.
Here's a video of the "tool" you can buy....at about 3:30 into video clip
http://www.youtube.com/watch?v=pCy0X...eature=related
Don't do what this goober did at 2:53 into video clip.
http://www.youtube.com/watch?v=_lhYb...eature=related
Old Apr 20, 2010 | 01:44 PM
joewill's Avatar
joewill
chisel and a hammer and vise grips, you aren't going to hurt your hardened steel output shaft..
Old Apr 20, 2010 | 10:58 PM
pwcheenie's Avatar
pwcheenie
Thank you for the advise. I bought a seal removal tool from horbor freight but it is too big to get in behind the seal and pry off of the shaft. Guess I"ll try the hammer and chisel.
Old Apr 20, 2010 | 11:58 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Chunk it out in pieces, if you have to. Just don't mess up the aluminum housing.
Old Apr 21, 2010 | 01:36 PM
TimAT's Avatar
TimAT
Pack the cavity on the back of the seal with grease before you drive it back in. That will reduce the chance of dislodging the garter spring around the inner part of the seal. Without that spring in place the seal is 90% worthless.
Old Apr 21, 2010 | 09:58 PM
pwcheenie's Avatar
pwcheenie
Thanks for the vidio link. After viewing it, I tried my seal removal tool. Hooked the inside of the seal, gave the handle a hit and the seal popped right out. Piece of cake!!!!
Old Apr 22, 2010 | 10:22 AM
jimvette999
To Removing Trans slip yoke seal
