L98
Old Apr 20, 2010 | 11:40 AM
jordan89's Avatar
jordan89
Default L98
Can the aluminum heads off of an L98 Corvette engine be used on our Gen I engines?
Old Apr 20, 2010 | 12:38 PM
Rmorgan&11's Avatar
Rmorgan&11
by what AFR is saying they are pretty much the same , only angeled plugs ??
http://www.airflowresearch.com/index.php?cPath=24_29
Old Apr 20, 2010 | 01:26 PM
Shark Racer's Avatar
Shark Racer
The L98 engine is a gen 1 motor as well.
They'll fit fine, not sure about spark plug and header/manifold clearance.
It'll raise your compression ratio quite a bit, that'll help with overall power and especially low-end torque. If you can get them for next to nothing, it's not a bad upgrade, but aftermarket heads (TF, AFR) are way better.
You'll need centerbolt valve covers, and they *might* have a different intake manifold bolt pattern as well.
Old Apr 20, 2010 | 02:08 PM
SteveG75's Avatar
SteveG75
L-98 heads have standard 6 bolt intake manifold. GM chnaged the center bolt angles on iron heads but aluminum stayed the same as old. 100% bolt-on.
Old Apr 21, 2010 | 12:23 AM
jordan89's Avatar
jordan89
There is a pair for $300obo. What would the compression ratio be? I have the L82 engine.
Old Apr 21, 2010 | 12:51 PM
jordan89's Avatar
jordan89
ttt
Old Apr 21, 2010 | 05:21 PM
Shark Racer
I think you'd probably see around 10:1, maybe a bit higher. It should be okay with the stock cam, but make sure to run 91 octane fuel and keep an ear out for ping.
Old Apr 21, 2010 | 08:12 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Be sure to have a machine shop pressure test them before you put them on. As an added bonus you'll be taking 40 lbs off the front of your car.
Old Apr 21, 2010 | 08:28 PM
jackson's Avatar
jackson
more than 10:1
stock L82 w/ L98-ZZ4 heads & 0.028" (5.8cc) gm 10105117 hgask =
= about 0.053" quench at about 10.7:1 scr ...
... L98-ZZ4 heads need either guideplates OR rail rockers & they don't have exhaust Xover & ex ports are about 0.100" higher than stock L82.
Old Apr 21, 2010 | 08:58 PM
PeteZO6's Avatar
PeteZO6
I have been running those heads for years with a LT-1 intake. Hooker Super-Comp headers clear the plugs. I had to cut down a spark plug socket to fit the tight quarters, but otherwise no clearance issues.
Cheers,
Pete
Old Apr 21, 2010 | 09:41 PM
Dantana's Avatar
Dantana
If budgetis your game these are a pretty good choice and you will get a decent amount of low end torque out of them, but I am counting the days until I go get a pair of aftermarkets that flow better. They are a little too tame for me.
Old Apr 22, 2010 | 01:55 PM
Shark Racer
Cheers,
Pete
Dig the use of the LT1 valve cover emblem.
Old Apr 22, 2010 | 07:42 PM
jordan89's Avatar
jordan89
I'm going to see if those heads are still available.
Old Apr 27, 2010 | 10:05 PM
PeteZO6's Avatar
PeteZO6
Thanks!!! The surprising thing was when I removed the C4 crossed flags emblem, the depressed area on the valve cover fit the C3 emblem exactly. I thought that was pretty of the General.
Cheers,
Pete
Old Apr 27, 2010 | 10:40 PM
tpi1986's Avatar
tpi1986
Watch out for the early aluminum castings, feb 1986 is when the l98 first got the alum head. Those early ones are known for cracking. They are fixable if you can weld aluminum, but kind of a pain the the rear. I out them on a 23 T bucket I built and had them on my 86 vette too. Both sets had cracks when I first went through them.
We ported them and ran them on the flow bench and got some pretty impressive numbers. Cheap head these days but can make some nice streetable power.
Hope that helps
To L98
