relay rod
Old Apr 20, 2010 | 01:12 PM
oleyellar72's Avatar
oleyellar72
Default relay rod
Hello All , I'm doing a rebuild on a 72 with power assist steering, and have all steering componets together. My question is the control vlv is hitting the tie rod so it must be bent . My question is can I straighten it enough to move it away from the tie rod?? It have to be realigned any right..
Old Apr 20, 2010 | 05:49 PM
gerry72's Avatar
gerry72
Tierods are cheap enough (under $20) you shouldn't bother to test your theory. Yes, you could bend the arm back but the joint may have taken a shot in a direction is was not likely designed for.
Old Apr 20, 2010 | 06:30 PM
oleyellar72
thankx Jerry72. Spent most of the day pulling apart and realigning everything I screwed up when I put it together the first time. Steering box included,but I got a 1.5 round on the wheel in both directions now
To relay rod
