DOT 5 to DOT3 fluid change - issues?
So in effect I didn't flush the system with anything other than synthetic. I did not want it contaminated. I now flush it about one a year.
Also on this forum. norvalwilhelm uses a truck belt driven power brake booster.
IMO...take the damn springs out from behind the caliper pistons...that will do more to firm upthe pedal than anything else...
GENE
Your reasons for removing dot 5 are your own (I agree). Drain as much as you can, buy a cheap turkey baster (don`t use the wifes!!) use it to suck the master as dry as possible. Any hardware store has denatured alcohol in the paint dept. run some through all the lines and out the bleeders you can also use cheap "Brake kleen" I would NEVER use anything else as (i believe) everything else leaves a residue.You can easily remove the calipers from their mounts one at a time and with a clear piece of plastic tubing on the open bleeders squeeze pads back moving the pistons into their bores to purge most of the old stuff out, use a container to catch the old fluid (i use a 20 oz plastic soda bottle). ...redvetracr
IMO...take the damn springs out from behind the caliper pistons...that will do more to firm upthe pedal than anything else...GENE
DOT 3.
I have owned this Vette for 32 years, and have been using DOT5 for over 10
years. I think I would have noticed a difference in the pedal.
What is the reason for removing the springs ?
I installed SS calipers over 10 years ago, from SS Brakes Corp., would they
have the springs or not ?
MSN71 --- I never did have a soft pedal after converting to DOT 5.
I did however rebuild the Master Cyl when I replaced the calipers.
Maybe the DOT 5 requires a very good condition Master Cyl. (Only a guess)
I have power brakes, maybe that's the difference. Don't know why some
people have a soft pedal with DOT 5 and others do not.
Barry
[Modified by Barry's70LT1, 12:52 PM 3/15/2002]
John
[Modified by theandies, 11:19 AM 3/15/2002]
