69 washer pump
Old Apr 27, 2010 | 10:31 AM
Nasavette's Avatar
Nasavette
Default 69 washer pump
I am looking for a source(s) for two items on the washer pump for my 69.
1. A y-fitting that connects the two hoses from the washer pump to the hose going to to the headlight washer valve. I can get a vacu-tite fitting that will work, but I'm looking for the correct black one.
2. A correct 3 port white pump on the washer pump assembly.
Thanks for the help.
Tim
Old Apr 27, 2010 | 11:06 AM
Nasavette's Avatar
Nasavette
After making this post and another one like it, it occured to me these type posts should probably be in the C3 parts wanted forum. Is this correct and if so I apologize for cluttering the forum with inappropriate posts. I'm relatively new in posting on the forum and want to respect the forum and use the correct protocol.
By the way, I want to thank all of the members of this forum whose posts have proved absolutely invaluable.
Thanks,
Tim
Old Apr 27, 2010 | 01:52 PM
Clams Canino's Avatar
Clams Canino
I would think you'd have better luck in parts wanted. No one will shoot you here for floating a question.
-W
Old Apr 27, 2010 | 05:47 PM
dennis's Avatar
dennis
Tim
Try here. they've been repop'n washers for awhile now. p F-19 in the catalog
http://www.melroset-tops.com/melrose_catalog.pdf
To 69 washer pump
