Changing power window switch?
Old Apr 28, 2010 | 01:28 AM
rp7056's Avatar
rp7056
Default Changing power window switch?
Can someone help me. Can someone please tell me how to change a power window switch for a 78 l48. Thanks in advance.
Old Apr 28, 2010 | 02:45 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Take the carpeted side panel off the console. 3 screws, one forward, one behind the seat, and one along side the seat. Takes a little effort to see the screws, but they're there.
You can get at the switches with either a 1/4" box or open end wrench or a 5/16" wrench, don't remember which.
Make sure the connector goes back on tight.
I like to open up the original switches and just clean the contacts rather than replace with repros. Very basic design.
Old Apr 28, 2010 | 08:17 AM
Aussie79's Avatar
Aussie79
One extra tip, dont overtighten the screws that hold the switches in position, they can be overtightened easily as they are a screw but have a hex head so over torque is easy, if you do overtighten them they will cause a bump in the centre console plastic that is both visible and ugly from the top, ask me how I know!!!!! Grrrrrr.
Old Apr 28, 2010 | 01:38 PM
...Roger...'s Avatar
...Roger...
also
I remove the front screw and only loosen the rear screw (the switch has a slot so it can slide). I also leave the connector on the switch and use it and the wiring to manipulate and hold the switch in place.
Old Apr 28, 2010 | 04:40 PM
rp7056's Avatar
rp7056
Thanks everyone for all your help.
To Changing power window switch?
