73 tilt column question
Old Mar 16, 2002 | 12:08 AM
lbell101's Avatar
lbell101
Default 73 tilt column question
hi!
Does anyone know if the tilt tele column in a 73 is the same as a 71?
Also, will the non tilt wheel work on a tilt column? Thanks!
Old Mar 16, 2002 | 10:49 AM
lbell101's Avatar
lbell101
Default Re: 73 tilt column question (lbell101)
ttt
Old Mar 16, 2002 | 11:50 AM
Jim Shea's Avatar
Jim Shea
I'm not exactly sure what your question is. But these are the answers per your posting.
The 1971 and 1973 tilt (actually T&T) steering columns are the same. The actual steering wheel is attached to a special hub by means of six screws. The steering wheels are the same between a standard (non-adjustable) steering column and a T&T.
However, the hubs are different between a standard steering column and the T&T column.
Old Mar 16, 2002 | 11:58 AM
lbell101's Avatar
lbell101
Default Re: 73 tilt column question (Jim Shea)
Hey Jim!
That's EXACTLY what I needed to know. Thanks!
To 73 tilt column question
