80 oil dipstick
Old Apr 30, 2010 | 09:08 PM
78pace's Avatar
78pace
Default 80 oil dipstick
Friends 80: from what we can see it looks like oil is leaking... where the dip stick tube meets the block.should there be an o-ring on there? I am pretty sure you can just wiggle that back and forth while pulling up to remove it. It is running down the starter right below where the tube goes in.........but with the starter in can't see all the way around the tube
Old May 1, 2010 | 04:16 PM
78pace's Avatar
78pace
PCV wasn't hooked to vaccum This caused gases to build in crank case which in turn forced oil out where dipskick tube meets block. fixed and life for the 80 is good
