Door Hinge Spring
Old Mar 16, 2002 | 10:56 AM
joe73vette's Avatar
joe73vette
Default Door Hinge Spring
The spring that works the door stops fell out of my 73, and I can't figure out how to get it back. Chevrolet Corvette Restoratio Guide shows a bent screwdriver tool to install, but doesn't show how. Anybody have any help, possibly with a picture? Thanks in advance. Joe
Old Mar 16, 2002 | 12:50 PM
Koz
Guest
Posts: n/a
Default Re: Door Hinge Spring (joe73vette)
Here's another write up.. https://www.corvetteforum.com/techti...D=67&TopicID=3
Sorry I don't have any picutres but I just did mine yesterday and it was easy.. Assuming yours is the same as my '80.. Use a flash light and find the wholes and grooves where it sits.. top and bottom. Once the spring is in the top whole and groove you position the bottom in the groove. The tool is then used to push the end of the spring in towards the car a bit to lign up with the bottom retaining whole. Use the tool for leverage to bend the spring.. I then tapped the spring upwards with a pair of plyers to seat it.. DAMM.. this is harder to explain then do.. Good luck.. You can always look at the other side if your not sure how it sits..
Old Mar 16, 2002 | 02:14 PM
jerryp58's Avatar
jerryp58
Fell out? It's not broken is it? Is it still "S" shaped?
I know I have an old Corvette Fever article on the procedure somewhere, but I don't think it had any good pictures of using the custom tool. I can try to post it if you can't find anything better. Let me know.
Old Mar 16, 2002 | 04:03 PM
DollaGreen's Avatar
DollaGreen
Default Re: Door Hinge Spring (jerryp58)
Mid America sells the "bent screwdriver". Its a door spring instal. tool for about $8. Makes life a lot easier. :smash: Comes with instructions!
[Modified by dollagreen, 2:05 PM 3/16/2002]
Old Mar 16, 2002 | 10:13 PM
joe73vette's Avatar
joe73vette
Default Re: Door Hinge Spring (Koz)
Thanks, Koz, for the website and write-up. I think I understand, and I will try it tomorrow. The spring is still intact, and I know how it is supposed to fit, but couldn't figure out how to get it in. That door always squeeked, even after I sprayed grease on the hinges. Must have been the spring. Joe
Old Mar 16, 2002 | 10:32 PM
Paul 75 L82's Avatar
Paul 75 L82
You have to have the bend screwdriver to complete this project. Other than that it's not to hard.
Old Mar 17, 2002 | 07:48 AM
Larry B.'s Avatar
Larry B.
Default Re: Door Hinge Spring (Paul 75 L82)
Make sure that the rollers work free and easy or the spring will pop back out or break. :smash:
Old Mar 18, 2002 | 09:46 AM
Koz
Guest
Posts: n/a
Here's my attempt at a descriptive pictures.. :crazy: Trying to hold the light and camera and tool..well..you get the idea.. Hope it helps! :cheers:
I was getting the grunting noise after installing the spring. The top of the spring was hitting the rollers.. Actually the door wouldn't stay open after I first installed it. Could be cause I'm on a ramp BUT the passenger side held SO I removed the spring and bent it out a tad to give it more tention...A few open and closes later the spring popped out. :confused: I checked the passenger side and noticed the bottom of the spring was pretty much up as high as it could go and the rollers were about 1/4 to 1/2 below the tip.. Reinstalled the drivers side the same and so far so good! Since it's Monday guess you know all this by now.. :lol:
Old Mar 18, 2002 | 01:00 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Joe,
I replaced my spring on Sunday, here's a link to my post:
http://forums.corvetteforum.com/zerothread?id=259556
Old Mar 18, 2002 | 01:03 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Re: Door Hinge Spring (74-Roadster)
I just installed a spring in my car Saturday. The tool makes all the difference. I had tried installing it with a regular screw driver, but it did not work. With the tool you wedge in on each side of the bottom of the spring and push in towards the car. The only additional tool I used was a hammer to wack the bottom of the spring up into the recessed hole in the hinge.
Mark B.
Old Mar 18, 2002 | 02:58 PM
Pogo72's Avatar
Pogo72
The magazine articles to check out are:
Corvette Fever: Feb. 1999
Vette : Oct. 1999
Al
Old Mar 18, 2002 | 03:13 PM
TQ67's Avatar
TQ67
Default Re: Door Hinge Spring (Sigforty)
If you have the tool and th instructions, do you need more than 1 person to do the job??
Thanks,
Old Mar 18, 2002 | 03:28 PM
Koz
Guest
Posts: n/a
Default Re: Door Hinge Spring (TQ67)
You need one hand to hold the spring.. One to hold the tool.. one to hold the flash light and one to hold your beer.. That's yourself and a couple female assistants..;) If your married and get along the wife will do.. If your married and the misses doesn't get involved with your car..like me.. you can do it yourself.. You sometimes wish you had that third hand but it would most likely just get in the way.. On a scale of 1 to 10 this is a :smash: :smash: :smash: :smash: and only cause you need a special tool.. Good luck!
To Door Hinge Spring
