Starter problems 79 vette
Old May 1, 2010 | 01:27 PM
cherry79's Avatar
cherry79
Default Starter problems 79 vette
The piece attached to the firewall with all the red wires and I believe its keeping the starter from working. Can any1 tell me what it is and if I can just take it out? Some1 had put an aftermarket alarm and some sound stuff that I have taken out and I'm wondering if this has something to do with those. Thanks
Old May 1, 2010 | 02:52 PM
TimAT's Avatar
TimAT
That's not a GM part. And yes, since you replaced the harness it probably is at least part of your troubles..
really, to know for sure, you'll need to track the wires from that solenoid and see where they go and hook up to.
Old May 1, 2010 | 04:20 PM
thegazman's Avatar
thegazman
Default thegazman
That's a solenoid (relay) for your starter. If it's wired properly it takes a heavy load off of your ignition switch when you engage the starter. If it's wired properly you should be able to place a jumper wire between the large lug on the left and the lug with the wire on the front and the starter will turn the engine over. It's not a bad thing to have and help your ignition swtch last longer. This type of solenoid is common on Ford vehicles.
Old May 1, 2010 | 04:56 PM
Tom1701's Avatar
Tom1701
http://www.chevyhiperformance.com/te...fix/index.html
Tom1701
Old May 2, 2010 | 12:47 AM
cherry79's Avatar
cherry79
Default Ended up being battery
Thanks for all the input. I had already removed it by the time I logged back on. Battery was showing 12v until i went to turn the key and then it would drop to 4. Just couldnt figure that out when working by myself.
To Starter problems 79 vette
