SBC Trick Flow Heads
Old May 2, 2010 | 01:56 AM
jordan89's Avatar
jordan89
Default SBC Trick Flow Heads
I have the chance to purchase a set of Trick Flow Twisted Wedge Heads at a good deal($450), but was wondering if I should get them. They are angle plug heads and I'm not sure if I should get them or not since they won't work with the side mounted headers. What do you guys think?
Old May 2, 2010 | 09:47 AM
cam cooper's Avatar
cam cooper
do u trust saler?are they super 23? are they complete?how many cc?i would check for flatness and magnaflux them.if complete check springs,valves,seats etc. are u sure they wont work with your headers they worked fine with mine there was plenty of room for plugs.if all checks out id say its a very good deal assuming they are complete
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Buy em' Mine are first generation Twisted wedge versions and other than the the original valve stem seals working their way off they have worked well.
I don't know about all the stories about Hookers not working with TF angle plug heads...here's proof they do..in living color
Old May 2, 2010 | 09:52 AM
cam cooper's Avatar
cam cooper
i thought that was the case like i said mine fit with all kinds of room
Old May 2, 2010 | 10:11 AM
midyearvette's Avatar
midyearvette
fwiw....the hardest pulling 350 i ever built for the street has the twisted wedge heads....had to swap out the valve springs....flat top pistons only! unless custom made......good luck
Old May 2, 2010 | 12:22 PM
jordan89's Avatar
jordan89
The guy said he only had them on for about 15,000 miles and they are the gen I version. Looks like I'm going to have to go for a ride and pick them up. Did you have to do anything to make them work with the hookers, any dings or something? That's a good looking engine.
Old May 2, 2010 | 12:48 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The Ford guys love these heads, I am surprised I don't see more Chevy's or more specifically C3's running these heads.
Old May 2, 2010 | 05:51 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Nothing, they fit with plenty of room all around. The only issue is number 2 plug is difficult to remove. I shortened a plug socket to get it done.
Old May 2, 2010 | 05:56 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I agree. The rub was of complicated valve train geometry, unequal pushrod lengths fast wearing guides etc. I've had no such issues
Old May 2, 2010 | 07:07 PM
cam cooper's Avatar
cam cooper
i agree on #2 plug i made a wrench that works great if those are complete heads thats a great deal on a very good set of heads if u change your mind let me know ill takem
Old May 2, 2010 | 09:15 PM
jordan89's Avatar
jordan89
I'm just waiting on the reply from the guy. I hope he still has them.
Old May 2, 2010 | 10:37 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
They flow great. The only issue with them is the offset intakes should use an offset rocker arm to eliminate side loading on the valve guide and the valve pockets are not aligned on some high compression pistons with high lift cams you could get interference. I think comp makes a rocker specifically for them. This is the reason they got a bad rap. A lot of these were installed with conventional rockers and subsequently had guide problems.
Old May 2, 2010 | 11:45 PM
jordan89's Avatar
jordan89
Well it turns out that the guy sold the heads, even after I called early in the morning and told him I would take them. Oh well, something else will come up later on. Thank everyone for the help.
Old May 2, 2010 | 11:47 PM
midyearvette
does summit still offer them new??
Old May 2, 2010 | 11:55 PM
jordan89's Avatar
jordan89
I've searched, but all that comes up is Ford heads. I think I'm just going to finish putting the Vette together and wait later on down the road. It would've been nice having some aluminum heads on the Vette, especially for $450.
Old May 3, 2010 | 01:53 AM
Solid LT1's Avatar
Solid LT1
Those heads can be a pain in the **** to get right. The few I was ever involved with required cutting the pushrod guide plates and welding them back together to get proper rocker centering on the valve stem tips. The design had a lot of potential but the details were not fully thought out when they released them. Better to look for some regulr 23 degree heads for your Vette.
Old May 24, 2012 | 09:37 PM
hadams's Avatar
hadams
Default Desperate for help
I bought a set of generation I Trick Flow Heads for my 75 L-82. I lucked out and only paid $300. I spent some time this evening checking valve to piston clearance and I was OK on both intake and exhaust (.250 and .300) roughly at the closest points. I called Trick Flow with the serial numbers and got them to e-mail me the specs and installation sheet. Proper length for the Pushrod was noted to be about .100” over OEM. That was pretty close for the exhaust valve. But……….I literally struggled for hours with a gear head buddy trying to determine the length of the Intake Pushrod. Just couldn't get it right. They make no mention of this issue in the specs and instructions. Ended up either too long or too short no matter what we did. Looks like there is some tribal knowledge out there about the need for an offset rocker for the intake valve and some negative feedback about varying pushrod lengths. I bought some nice Lunati 1.5:1 rollers but that isn’t working for the intake. Anyone know any more to help solve the mystery? More info on the offset rocker requirement that is not noted in the instructions?. I am literally struggling with this.
To SBC Trick Flow Heads
Old May 25, 2012 | 01:04 AM
Crepitus's Avatar
Crepitus
iirc TFS sells rockers for this head
Old Jul 15, 2012 | 03:31 PM
Luvshine's Avatar
Luvshine
7th Gear
I have a set of these available if you are still intrested. They are complete, except the dampers and have been freshend up. Found three of teh dampers broken during valve job. They are missing the dampers which add about 6# seat preasure closed. Everything else looked good,
I have have all teh studs, guides and roller tip rockers. $500 and they're yours.
Old Nov 29, 2012 | 09:53 PM
68post's Avatar
68post
I would be interested !
