valve adjustment
Old May 2, 2010 | 01:16 PM
77bluvette's Avatar
77bluvette
Default valve adjustment
rebuilding a 350 to put in my 79 and have been told that the valves need to adjusted a certain way or else it will wipe my cam!!!!! new to the chevy side of things please help
Old May 2, 2010 | 02:37 PM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
http://forums.corvetteforum.com/c3-t...djustment.html
This a link from one of our greatest forum people. I just followed and worked great. You need to know if you have hydraulic or solid lifters. At the bottom of the link is Lars email address.
Gary
Old May 2, 2010 | 03:12 PM
77bluvette's Avatar
77bluvette
this link is to my post.....
Old May 2, 2010 | 03:42 PM
Sorry about that. I'll try again. You should have hydraulic lifters no matter which engine for that year.
http://www.australiancorvettes.com/d...valve_lash.pdf
Old May 2, 2010 | 06:09 PM
vettes4evr's Avatar
vettes4evr
Very well written. Is there one for solid lifters? I just picked up a '72 LT-1 and might as well do this while replacing the valve cover gaskets.
Old May 2, 2010 | 06:37 PM
The Chilton manual has directions for hydraulic and solid lifters. I am sure online somewhere will have adjustments for solid lifters.
Old May 2, 2010 | 07:57 PM
77bluvette's Avatar
77bluvette
Thank you for the help
Old May 2, 2010 | 08:13 PM
lars's Avatar
lars
Yes, I have the definitive solid lifter adjustment article written by John Hinckley and Duke Williams. E-mail me for a copy:
V8Fastcars@msn.com
No, don't use the Chilton's manual for valve adjustment.
Lars
Old May 2, 2010 | 08:22 PM
vettes4evr's Avatar
vettes4evr
I only use a Chiltons manual to hold up the other (worthwhile) Corvette reference books in my book case.
Old May 2, 2010 | 08:42 PM
MalibuVLX's Avatar
MalibuVLX
How about oil choice for the new motor. I have been reading more and more about the newer oils do not have all the additives that help protect the hydraulic lifter cams. I have read that ZR-1 oil still possessed the needed components that are easier on the cam lobes and lifters. Any comments? Or is this bull.
Old May 2, 2010 | 09:27 PM
Gordonm's Avatar
Gordonm
Sent you a PM
Old May 2, 2010 | 10:49 PM
You are welcome
Old May 2, 2010 | 10:51 PM
I agree with Lars on Chilton for hydraulic lifters. Bad advice there
Old May 3, 2010 | 11:42 AM
77bluvette's Avatar
77bluvette
i bought a speed pro cam and they reccomend a zinc additive for the break-in period. if that is what your referring to. on regular motor oil i use royal purple or amsoil. hope this helps...
Old May 3, 2010 | 02:26 PM
billla's Avatar
billla
St. Jude Donor '14
Lars, since we're on the topic may I ask for your opinion of the "companion cylinder" method for valve adjustment?
to you for all you do for the board!
Old May 3, 2010 | 02:27 PM
billla's Avatar
billla
St. Jude Donor '14
See the sticky at the top of this section
Old May 3, 2010 | 02:45 PM
RATT7's Avatar
RATT7
I have adjusted my valves based on Lars's paper to, straight forward and easy to do as per the firing order.
To valve adjustment
