Engine Part. What is it?? (pic inside)
Old May 3, 2010 | 03:45 PM
Nitro DarkSide's Avatar
Nitro DarkSide
Default Engine Part. What is it?? (pic inside)
I noticed that when the car is cold i have a liquid leak ... it lasts a couple of minutes and that's it.
Is it normal? what is that part?
Old May 3, 2010 | 04:25 PM
7t5's Avatar
7t5
St. Jude Donor '14
Take another shot a little farther back so I can see where those 2 hoses on the right are going. It looks like a coolant divertor valve.
Leave a little more info on year of car.
Old May 3, 2010 | 04:52 PM
...Roger...'s Avatar
...Roger...
Looks like a heater shutoff valve but with an extra nipple.
Old May 3, 2010 | 04:54 PM
7t5's Avatar
7t5
St. Jude Donor '14
That was my thought, but I cannot find one listed in the Doc Rebuild catalog, which normally has everything with good illustrations. It looks stock to my amatear eye, but who knows. I wonder where the coolant goes when the valve closes.
Old May 3, 2010 | 04:56 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
Agreed, heater control valve.
Old May 3, 2010 | 06:07 PM
glackore's Avatar
glackore
It is definitely a heater control valve - might not be the OEM style - could be someone cobbed one in that is for another application.
Old May 3, 2010 | 06:12 PM
Mashman's Avatar
Mashman
It is a vacuum controlled shutoff valve - I got one from napa.
The advantage of this one is that it shut off both heater hoses at the same time.
It's not a corvette part, and it's for something a lot newer - I want to say a 1990's honda - or something like that.
Old May 3, 2010 | 07:00 PM
Nitro DarkSide
Yeah, you are right guys! I remember the seller told me about that.... he installed that...
mm... so is that water normal when the car is cold?
Old May 3, 2010 | 09:18 PM
7t5's Avatar
7t5
St. Jude Donor '14
Leaking antifreeze is never normal. Fix it before it strands you.
Old May 4, 2010 | 07:59 AM
Nitro DarkSide
but it happens just when the car is cold, for a couple of minutes...... suggestions about how to fix it? i have to replace that thing?
Old May 4, 2010 | 08:21 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I'd wait till the car is cool and tighten all the clamps , start it and look at it , it may leak cause of a crack ! Have someone switch from cold to hot inside and see if it moves ok, Ron
To Engine Part. What is it?? (pic inside)
