Anyone use the rear defogger wires as radio antenna with any sucess ?
Like the title says I know someone did this a while back a reported it worked good.
That is he connected his radio antenna input to the wires in the rear window that are used for defogging. I don't have a heater, A/C I just recently took the controls out of console and put a plate in there, so I certainly don't need these wires to de-ice anything
Would like to know if anyone else has done it, how to do it and more importantly does it work good ?
I cant help you on with the how... but i can verify that yes it works. The previous owner to my 79 vette has it wired that way, but the "how" is another question beyond my knowledge!
Received 3,233 Likes
GM years back tried the windshield antenna- however they used a dipole design- Each side of the antenna was about 31 inches in length. Worked OK for FM but sucked for AM. (Same as an old TV antenna design)
The best design is the stock antenna- known as a vertical a ground plane. Which is omnidirectional unlike the TV 'dipole design.'
For a ground plane- FM- The ideal antenna would be around 31". For AM- a couple hundred feet. You also need a "ground plane"- and you don't have that w/ a Corvette body since it's not metal. That's what GM tried to do w/ the steel panel underneath the factory antenna.
The defroster wire is horizontal- will work OK for FM but good luck w/ AM. It will be directional and some loss since it's not vertical.
Take the center conductor and attach to the defroster wire- Disconnect the other side. Try to cut back the shield as minimal as you can-then run the shield to a ground.
And make sure the defroster is not hooked up- you'll toast the radio.
Richard
Richard
I figure you were just trying to reduce your C/D.
Seems you would need to pull both power and ground connection from the defroster connection at the rear window, and connect up your center antenna lead from the antenna coax cable.
After that, let us know how it works.
You are right- that design they've been using since the late 1990s is totally different-Where as the whole window has a metal oxide coating between the layers of glass. A lot of newer cars also have a 'diversity' antenna system- Basically two antenna and the electronics switch between them- the second antenna is the grid. Helps cut out the multipath- or static on FM.
I was referring to GM's design used in the 80's- which is similar to what Motorhead is try to accomplish
"I hope you don't get a little to warm or cold, honey"
Man the camera picks up any little dings or scratches I can't even see when I get in
I'll probably just fix the OEM antenna, I don't want to go through all the hassle and not have good reception. Not to say the OEM mast antenna is that good in the first place
