brake line routing question....
Old May 3, 2010 | 11:53 PM
razman's Avatar
razman
Default brake line routing question....
i'm putting my new calipers and brake lines on my 68' BB chasis (frame off resto)
on the rear calipers there is a steel line from caliper to the rubber brake hose....since this is a big block car, i have a rear sway bar. does the steel line go inboard around the bar bracket or between the bracket on the trailing arm and the caliper??? (hope this makes sense)
i'm guessing that it routes inboard around the bracket then to the caliper. any body know for sure, or have pics? thanks, Rick
Old May 5, 2010 | 01:54 AM
razman's Avatar
razman
thanks a bunch!
Old May 5, 2010 | 02:07 AM
Steve COSD's Avatar
Steve COSD
The line you are reffering to is pre bent. It should also have the wound wire around the line. You will find that there is about only one way that that line will install.
Good Luck
Old May 5, 2010 | 07:06 AM
Clams Canino's Avatar
Clams Canino
I don't believe all the T/A lines have the wound wire, depending on the year.
But yes, they only go on one way.
-W
Old May 5, 2010 | 09:02 AM
Duke94's Avatar
Duke94
Here's my 78' with sway bar, should be close to yours I would think.
Gary
Old May 5, 2010 | 05:20 PM
razman's Avatar
razman
thanks everyone........that helps a bunch! Rick
Old May 5, 2010 | 09:02 PM
eastltd's Avatar
eastltd
Sorry if I'm too late with the pictures, but hopefully they will help
Old May 6, 2010 | 01:55 PM
razman's Avatar
razman
thanks, the pics were very helpful!
To brake line routing question....
