K-motion K-700 springs with Vortecs?
Old 05-04-2010, 12:37 AM
Bugman Jeff
Bugman Jeff's Avatar
Default K-motion K-700 springs with Vortecs?
I'm collecting parts for a Vortec swap. I keep reading that the stock springs aren't the best. I'm going to be using a Summit K1103 cam in it. Looking through spring size/weight specs, it looks like the K-Motion K-700 springs should fir the heads and are only 30 Lbs heavier than what Summit recomends for the cam(464 VS 430). They're also only $50 a set. Has anyone had any experience with these springs? Are they a good match for the vortec heads and Summit cam? What are the other low dollar alternatives? I keep seeing the "Z28" spring recomended, but no one ever says where to get them or lists a part number. How do those compare to the K-motions? Thanks for the info.
Old 05-04-2010, 01:21 AM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Why don't you want to use the springs the cam manufacturer recommends ?
Old 05-04-2010, 01:47 AM
Solid LT1
Solid LT1's Avatar
Vortecs have a short installed heigth and I would consider running "beehive" springs instead of the K-700 springs. I think your seat pressure will be too high if your running std Vortec valves. Also the retainers and keepers on Vortecs are pretty cheap, I wouldn't use them in a performace application.
Old 05-04-2010, 06:32 AM
cam cooper
cam cooper's Avatar
I have exp. with k motion springs used to be good now there cheap china junk buy good springs.comp,isky,etc
Old 05-04-2010, 08:01 AM
Bugman Jeff
Won't fit unmodified Vortec heads, the ID is to small by .005".
Old 05-04-2010, 09:31 AM
Rotonda
Rotonda's Avatar
I used a Crane 99846 H-11 steel spring with stock retainers and +.050" valve locks for a 1.750 installed height. These springs fit over stock vortec valve boses and allowed me to use a .480 lift roller camshaft without worries. They are pricey.
jackson
jackson's Avatar
production vortec springs are AOK for 1103 cam ... that cam nearly same as in gmpp crate 350HO 330hp & it has plain production vortec heads & springs. that spring gm p/n 10212811 . this should fit AOK ... but much more cam w/ vortecs is primary limitation at production vortec RETAINER ... there's a bulge on underside just around the valve stem & that moves real close to top of VS seal ... but it should be ok LESS THAN .475" valve lift. If used heads, suggest a fresh set of production vortec springs & fresh seals ... probably cheap on fleabay ... maybe cheap right there at your hometown gm dealer. this matter addressed zillions of times prior.
ya don't need pricey springs w/ 1103 cam in street motor
FYI ... I've posted z28 spring p/ns before:
sealed power p/n VS739R
elgin p/n RV943X
comp p/n 981
Old 05-04-2010, 11:03 AM
jackson
jackson's Avatar
FYI
just put a gage on two stock unmodified production heads & measured bottom OD of guide boss
old iron sbc 400 head about 0.770" or less
iron sbc vortec 350 head about 0.870" or less
your conditions/results may vary ... y'all do the math on which spring ID fits what head OD
Old 05-04-2010, 11:09 AM
Solid LT1
Solid LT1's Avatar
Other alternative is late model LS1 beehive setup, but your still shopping for retainers and locks. Like I said before, I wouldn't use OEM Vortec stuff in a HP motor not even a 6000 RPM one.
Old 05-04-2010, 01:17 PM
jackson
jackson's Avatar
Default GM does ... with much success & satisfaction
GMPP includes that same vortec 10212811 spring & same retainer 10241744 & same keepers 24503856 & same 24502476 cam in its CT350 sealed race crate p/n 88958602 ... its most popular race crate ... dunno how many tens of thousands in service? ... they're very reliable ... plenty go 3-4 seasons without part(s) replacement/freshening ... am unaware of any wide-spread failure of any sort. Somehow, GM has it figured out.
Old 05-04-2010, 02:02 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
Honestly, would you buy Vortec heads if performance was your ultimate goal?
Old 05-04-2010, 04:05 PM
Rotonda
Rotonda's Avatar
1) If you are looking for vortec springs, I have a set of brand new take-offs. Cheap. PM me.
2) Retainers - When installed, I found Comp Cams retainers to come lower down the valve stem than stock. That's why I'm running stock.
Old 05-04-2010, 09:48 PM
Solid LT1
Solid LT1's Avatar
There is NO WAY that those springs are the same as the ones used in the production truck Vortec head, maybe a marine use spring but, the truck springs are WEAK! I wouldn't use the truck retainers/valve locks on any motor I would build or drive hard but, I'm a pretty hard driver. If you want to save $100 for a set of springs/retainers/locks, so be it, I wouldn't!
Old 05-05-2010, 12:05 AM
Bugman Jeff
Thanks for all the info. Just the kind of stuff I was looking for
Old 05-05-2010, 12:26 AM
MotorHead
MotorHead's Avatar
What you want to know is seat pressure open and closed, not spring rate and then you start to figure out the rest.
Part Number: 99848-16 BACK TO LIST
Outer Diameter Top 1.255
Inner Diameter Top .870
Damper NO
Seat Pressure @ Installed Height 114 lbs. @ 1.700
Open Pressure and Height 340lbs. @ 1.200
Coil Bind 1.153
Average Spring Rate 432 lbs./in.
Maximum Net Lift 0.487
K-700 1.265 diameter single Chrome Silicon spring that is good for camshafts
with up to .500 valve lift.
120# @ 1.700 - 375# @ 1.150 - coil bind @ 1.050
Old 05-28-2011, 06:15 PM
sickstysevin
1st Gear
sickstysevin's Avatar
Default vortec heads
Honestly, because for 150 bucks a set off a truck, car craft has made 420+ horsepower out of the box with a few gm performance parts, with a little work they are getting almost 500 foot lbs of torque. All of this below 6000 RPM, you get the benefits of one of the best factory port designs from the lt head, but you don't have to run the crappy lt configuration with the worthless, problematic distributor location(vortec intakes for carbs are under 150 bucks) or an aggresive profile high lift cam loosing engine vacuum. The vortec has superior flow characteristics to almost all gm factory production heads in the .200-.400 lift range.
heres the proof in black and white.
http://www.chevyhiperformance.com/te...ild/index.html
To K-motion K-700 springs with Vortecs?
Quick Reply: K-motion K-700 springs with Vortecs?
