c3 expansion valve replacement
Old May 5, 2010 | 01:31 PM
Kap142's Avatar
Kap142
Default c3 expansion valve replacement
1972 Coupe BB with factory air.
Hey guys. I (as in similar threads) are up grading my facotry A/C system to a more modern system.
So far the project is going well....... I have run into a heck of a problem getting the expansion valve nuts broken lose so I can replace the valve with the new one. Space is very limited and even with crows foot flaired wrenches I can't get the fitting to break free. I am afraid of damaging the aluminum tubes to the evaporator. I've hit um with blaster and let it sit.
It appears to me that the bottom tube on the exp. valve has it's own fitting and then it appears there is one nut locked against the top nut.
Any "secrets" to help a shade tree machanic resolve the removal issue?
Old May 5, 2010 | 07:22 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
Well i dont have any application specific help, but if the nuts are stuck, and if you tried some pb blaster on it and they still wont break, try tightening the stuck nut and that may break any seal that rust or crud has formed then back it out.
(i took this from a forum member that posted on a tread about stuck intake manifold fittings and he said to try tightening them and then loosening them instead of just loosening them to break any bond that formed because of garbage on the threads so props to him for this idea!)
Good luck with the project!
Will
Old May 5, 2010 | 08:01 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Have you tried removing the side vent and going in through there?
That's what I do. Much more room to work.
Old May 6, 2010 | 12:13 PM
Kap142's Avatar
Kap142
Very sharp. The tightening first did work and she eventually gave up the ghost and came out as she should. Will, I thank you.
Now the fun of removing the POA valve (and I thought the evaporator was a PITA!)
Ken
Will
Old May 6, 2010 | 12:14 PM
Kap142's Avatar
Kap142
Ummmm another great thought. It might give me more room for the POA removal.
Thank you
Old May 9, 2010 | 12:47 PM
Will's'74VetteL-82
Ken
You're welcome im glad i could help and that you got that stuck nut out. Good luck with the rest of the project!
Will
Old May 9, 2010 | 07:50 PM
Rockn-Roll's Avatar
Rockn-Roll
Below the POA valve is a piece of sheet metal which can be removed and the POA valve will drop straight down, otherwise there isn't enough clearance to get it out and the new one in without scraping the paint off the engine compartment and/or damaging something.
Old May 9, 2010 | 08:18 PM
Kap142's Avatar
Kap142
Have, by going through the shark grill, been able to finish removing the old POA and evaporator. Gave me a chance to clean up the area too. Have since reinstalled the new POA and expansion and reconnected the hoses. Tomorrow the S6 goes in and soon after she'll be charged.
I did flush the whole system several times and OMG the crap that was in there.
I still wonder if the cooling will improve? I know their will be less drag on the motor but I have many more horses then I need now so that's not the motivation. I wanna be cool and comfy.
Old May 9, 2010 | 08:26 PM
Kap142's Avatar
Kap142
Also found that I need to replace a section of the wiring harness from the A/C relay all the way to the compressor. At some time prior to my ownership the relay connectors all melted and I'm not even sure the connectors are on the correct posts (I've never had a high speed on my A/C fan even with parts replacements. Any ideas?
Thanks guys,
Ken
Old May 9, 2010 | 09:15 PM
airtime's Avatar
airtime
when you reinstall everything make sure you get some ester oil and lube the orings so they don't pinch when reinstalling them and add a little to the threads. so the next guy will not have to go thru what you did to get the nut loose. ester is a/c oil. they make r-12 and 134 oil.
Old May 9, 2010 | 09:17 PM
airtime's Avatar
airtime
can u post a pic of the hose that goes from the poa valve to the rear of the compressior? i am working on my a/c this week and i am missing that particular hose. thanks
To c3 expansion valve replacement
