Anyone able to help speedometer cluster
Old May 6, 2010 | 07:42 AM
Valic's Avatar
Valic
Default Anyone able to help speedometer cluster
Ok here is what i know about the car
recently purchased
1979 corvette 350 4bl
replacement engine
auto transmission
not sure what other info might be needed but heres the problem
my speedometer does nothing. my odometer doesnt work.
my tachometer reads 7k rpm and never moves just stays all the way over to the right even when vehicle is off
Old May 6, 2010 | 08:32 AM
hugie82's Avatar
hugie82
Speedo and tach are two different animals. The speedo is mechanical, you most likely have a broken speedo cable. The tach someone else will chime in. I never had a problem with mine but I do know they sell curcuit boards and rebuild them.
Old May 6, 2010 | 12:56 PM
Valic's Avatar
Valic
Today i followed the the speedo cables and they are all intact and connected.
Old May 6, 2010 | 01:06 PM
1Fordman's Avatar
1Fordman
Does your car have 2 cables one from the dash to a transducer for the cruise control and then another cable from the transducer to the transmission? If so the transducer has probably gone bad. Also you need to look at the cable itself inside the cable housing just because they're connected doesn't mean the cables are good.
Go to the Willcox website, they probably have a troubleshooting printout for the tach.
Old May 8, 2010 | 12:13 PM
Valic's Avatar
Valic
so i have disconnected the cables to the transducer and spun the bottome and the top moves with it and i spun the cable running to the dasha nd the speedo moves what next any sugestions?
Old May 9, 2010 | 11:48 AM
Valic's Avatar
Valic
ok so new update i removed the speedo cable from the tranny and turned it there and the speedo moves but connected i still have nothing and ideas?
Old May 9, 2010 | 12:12 PM
C3 4ME's Avatar
C3 4ME
If the speedo works when the cable is disconnected from the trans and spun, then something is wrong with the speedo gears inside the trans. My 79 is a 4 spd, and there is a small nut that holds a small cover over the speedo gears. Just take that nut off and you'll get to the gears, and then I would check them out for damage. I assume an auto is similar, but don't know.
Old May 9, 2010 | 12:19 PM
Valic's Avatar
Valic
cool then thats the next step thanks.
To Anyone able to help speedometer cluster
