12 Volts for Coil
Old May 7, 2010 | 10:21 PM
duescherc's Avatar
duescherc
Default 12 Volts for Coil
Upgraded to electronic ignition for the distributor with Pertronix coil on 72 small block and wondering where I should get the full twelve volts for the coil. Don't know if there is any device (such as the windshield wipers, etc.) that is keyed by the ignition and not running on accessory portion that I can hook into for the full 12 volts. Or, should I go back to the fuse panel and hook into the ignition portion of the fuse block.
Old May 7, 2010 | 10:45 PM
KTKelly's Avatar
KTKelly
Sort of answered the question on your own....
Old May 7, 2010 | 11:33 PM
7T1vette's Avatar
7T1vette
And don't forget to buy a 12 volt coil to replace the stock coil.
To 12 Volts for Coil
